NAT on the ISR 886VA via FastEthernet
Exonix
We use ISR 886VA as Internet Router via VDSL.
Now we need to switch this router to use FastEthernet as WAN port. Here is the current configuration:
interface Ethernet0
 description WAN
 no ip address
 ip nbar protocol-discovery ipv4
 service-policy input Hosts
interface Ethernet0.7
 description VDSL VLAN 7 tagged
 encapsulation dot1Q 7
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface FastEthernet0
 description LAN Trunk
 switchport mode trunk
 no ip address
interface FastEthernet1
 description WAN
 switchport access vlan 4
 no ip address
interface Vlan1
 description LAN
 ip address 10.254.1.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in max-reassemblies 64
interface Vlan2
 description Guest WiFi
 ip address 10.254.2.1 255.255.255.0
 ip access-group 104 in
 ip helper-address 10.254.1.8
 ip flow ingress
 ip nat inside
interface Vlan4
 description WAN
 ip address 192.168.102.254 255.255.255.0
 ip flow ingress
 ip nat outside
interface Dialer0
 description VDSL TELEKOM
 ip ddns update hostname XXXXXXX.dyndns.org
 ip ddns update dyndns
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 load-interval 30
 dialer pool 1
 dialer-group 1
 no keepalive
 ppp authentication pap callin
 ppp pap sent-username **********@********* password 7 ************
 ppp ipcp dns request
 ppp ipcp mask request
 ppp ipcp route default
 no cdp enable
ip nat translation tcp-timeout 14400
ip nat inside source list 101 interface Dialer0 overload
access-list 22 permit 10.254.1.0 0.0.0.255
access-list 101 deny   ip 10.254.1.0 0.0.0.255 10.253.3.0 0.0.0.255
access-list 101 deny   ip 10.254.1.0 0.0.0.255 10.255.10.0 0.0.0.255
access-list 101 permit ip 10.254.1.0 0.0.0.255 any
access-list 101 permit ip 10.254.2.0 0.0.0.255 any
access-list 104 permit udp host 10.254.1.8 eq bootps 10.254.2.0 0.0.0.255 eq bootps
access-list 104 permit udp host 10.254.1.8 eq bootpc 10.254.2.0 0.0.0.255 eq bootpc
access-list 104 deny   ip 10.254.2.0 0.0.0.255 10.254.1.0 0.0.0.255
I have tried to change:
to:
ip nat inside source list 101 interface FastEthernet1 overload
and add:
ip route 0.0.0.0 0.0.0.0 192.168.102.1
But it didn't help. What should I do to have NAT via FastEthernet1?
Thank you in advance!
Have you also removed the old config pointing to dialer0? That also has to be done to make it work. And the NAT-command has to use the IP-interface:
ip nat inside source list 101 interface Vlan4 overload
the default route needs to be:
ip route 0.0.0.0 0.0.0.0 Dialer0
yeah, that's what I did and it works now. Also, I had to disable Dialer 0 Interface at all.
