NAT overload backup
prafuljaded
Level 3
Level 3
Does Cisco router have any option of specifying NAT overload backup, may be with use of route-maps.For ex:If outside interface s0 is configured for NAT overload, I want to failover to outside interface s1, if s0 goes down?
Praful
6 Replies 6
mheusinger
Level 10
Level 10
this can be achieved with normal routing. Example:
interface ethernet0
ip nat inside
interface serial0
ip nat outside
interface serial1
ip nat outside
ip nat inside source list 1 Serial0 overload
ip nat inside source list 1 Serial1 overload
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Serial1 250
access-list 1 permit any
As long as serial0 is up all traffic will use S0. when S0 is down then everything will be routed through S1 and NAT translations are built with the S1 IP address.
Hope this helps
Martin
I know from testing that this works, just replace E1 and E2 with S0 and S1.
interface Ethernet0
ip nat inside
interface Ethernet1
ip nat outside
interface Ethernet2
ip nat outside
ip nat inside source route-map Ethernet1 interface Ethernet1 overload
ip nat inside source route-map Ethernet2 interface Ethernet2 overload
access-list 105 permit ip 10.0.0.0 0.255.255.255 any
access-list 105 permit ip 172.16.0.0 0.15.255.255 any
access-list 105 permit ip 192.168.0.0 0.0.255.255 any
route-map Ethernet1 permit 10
match ip address 105
match interface Ethernet1
route-map Ethernet2 permit 10
match interface Ethernet2
Thanks for your replies. I have tried it in lab, but the second NAT overload command overwrites the first one.
I am not sure if we can have two NAT overload commands at the same time.
Praful
If the links are getting connected to the same SP via different physical paths (for reduandncy purpose) then u can make use of logical loopback interface in ur router.
Just configure overload over the loopback interface and make sure u have static default routes placed in ur router as well the static routes to have the reachability for ur loopback ip with & without admin distance @ the SP end via the respective WAN links.
regds
Hi Praful,
sorry for making mistakes above.
The correct commands would be
ip nat inside source list 1 interface Serial0 overload
ip nat inside source list 2 interface Serial1 overload
access-list 2 permit any
Hope this helps
Martin
Good day,
How about your issue ?
Best regards.
