NAT overload from VRF to Global
Im trying to make a setup where several VRF´s (In this case called guest) share a single internet connection. The internet connection are in the global routing table.
I have made the route in the VRF pointing to the internet
default gateway
and used the "global" keyword. Likewise I have also made
NAT
overload and marked interfaces with "inside" and "outside"
Any device connected to the
VRF guest
do get a IP from the dhcp and can
ping the default gateway
in the subnet (172.16.237.254) but no further.
Anyone knows what I´m doing wrong?
vrf definition guest
rd 234:432
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip dhcp pool guest
vrf guest
network 172.16.237.0 255.255.255.0
dns-server 208.67.222.222 208.67.220.220
domain-name guest.int
default-router 172.16.237.254
interface GigabitEthernet9
description Internet
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface Vlan200
vrf forwarding guest
ip address 172.16.237.254 255.255.255.0
ip nat inside
ip nat inside source list guestSubnet interface GigabitEthernet9 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet9 192.168.1.1
ip route vrf guest 0.0.0.0 0.0.0.0 192.168.1.1 global
ip access-list standard guestSubnet
permit 172.16.237.0 0.0.0.255
2 Accepted Solutions
Hello
ip nat
GigabitEthernet9
vrf guest
ip route 172.16.237.0 255.255.255.0 vlan200
res
Paul
Kind Regards
Paul
as an alternative to Paul's solution, you could also use the config below (changes marked in bold):
rd 234:432
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip dhcp pool guest
vrf guest
ip nat enable
duplex auto
speed auto
no cdp enable
interface Vlan200
ip nat enable
ip nat pool GUEST 192.168.1.2 192.168.1.2 prefix-length 24
ip nat source list guestSubnet pool GUEST vrf guest overload
Hello
ip nat
GigabitEthernet9
vrf guest
res
Paul
Kind Regards
Paul
rd 234:432
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ip dhcp pool guest
vrf guest
ip nat enable
duplex auto
speed auto
no cdp enable
interface Vlan200
ip nat enable
