NAT / Port forwarding not working
Hi guys,
I'm having some issues with  port forwarding on my 1921 ISR, it was all working fine about a week ago... Then overnight (isr restarted due to power failure) it stopped working... I've gone over my config again, and again... Checked IP addresses, firewalls and tested connecting from the LAN and all works as expected. 'I just can't seem to connect from the outside -> in :(
controller VDSL 0/0/0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
no cdp enable
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
mac-address 7050.afb7.c5da
no ip address
ip nat outside
interface Ethernet0/0/0.101
encapsulation dot1Q 101
ip dhcp client request classless-static-route
ip dhcp client client-id hex ************************************
ip dhcp client hostname ************@*****|********
ip address dhcp
no ip redirects
no ip proxy-arp
ip nat outside
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat inside source list 100 interface Ethernet0/0/0.101 overload
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
ip nat inside source static tcp 192.168.10.202 80 interface Ethernet0/0/0.101 8880
Thanks in advance for any help!
If you change this port 8880 to another ports, its working?
Jaderson Pessoa
*** Rate All Helpful Responses ***
10 Replies 10
Jaderson Pessoa
This 192.168.10.202 80 is accessible from internal clients?
Jaderson Pessoa
Hi Jaderson,
Yes, it is. :)
@Y. 'FoAmY' Vandenbossche try it;
no ip nat inside source static tcp 192.168.10.202 80 interface Ethernet0/0/0.101 8880  < certify the port
 clear interface ethernet0/0/0.101
clear counters  ethernet0/0/0.101
shutdown and shutdown under interface 0/0/0.101
 maybe it is a bug
Jaderson Pessoa
Tried that already, just tried again... No dice :(
Hello
from the rtr if you telnet to 192.168.10.202 80 source gig0/0.10  - do you get connection?
From outside telnet again to your public IP address on port 8880
sh ip nat translations
Kind Regards
Paul
from the rtr if you telnet to 192.168.10.202 80 source gig0/0.10  - do you get connection?  :    yes, connects fine...
From outside telnet again to your public IP address on port 8880  :    no connection, times out :(
VDB-R1# sh ip nat trans
tcp xxx.xxx.xxx.xxx:8880   192.168.10.202:80     ---                   ---
Jaderson Pessoa
Indeed this fixes it, I guess I'll come up with another port to use!
Thanks for your help everyone!
Great, maybe theret this port stayed in block state in your router "bug" i dont know..
But great that your problem was solved.
Jaderson Pessoa
Hello
Shouldn't really make much difference but can you try using another source port maybe tcp 80 and amend the acl to deny that host from the dynamic nat
access-list 100 permit deny host 192.168.10.202  any
Kind Regards
Paul
