PPTP and L2TP connection between Cisco 1921 Routers
Robert Chan
Hello Everyone i need some help, was trying to set up a connection between 2 remote sites using a PPTP or a L2TP vpn connection. I am using 2 Cisco 1921 Series Router both with universalk9 and securityk9 licenses. I was told by a previous cisco personnel that the reason these connection were not able to be established an running is because of the cisco license.
Can someone please advise me on what i should do here. Really would appreciate the help and support on this matter. I am a bit confused on how this could be the issue cause both routers have the same license installed and are permanently actvated.
Please see the information i took from the both cisco routers:
Technology Package License Information for Module:'c1900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
data None None None
and the other router
data None None None
Please help really need the help of the greats and guru in this.
what exactly is not working ? Post the full configurations of both sides...
