Configuring GRE VPN Tunnel
Stuart D
I've configured a VPN tunnel between two routers via a third, but am having some trouble using the tunnel.
In this scenario I have two sites connecting via a VPN through a third router acting as an ISP, however when issuing a traceroute it comes up as having passed through the ISP router. Would I be correct in thinking that a functioning tunnel would not show this middle step in the traceroute? This makes me think the tunnel is not being used and it is just using OSPF which I'd already set up between the three routers.
If anyone could help fix this, I'd be very grateful!
Here are the configurations for the three routers:
Site1:
interface Tunnel0
ip address 172.16.12.1 255.255.255.252
mtu 1476
tunnel source Serial0/0/0
tunnel destination 10.5.5.1
interface GigabitEthernet0/0
ip address 10.1.1.2 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.1.2.2 255.255.255.252
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 198.222.123.17 255.255.255.240
clock rate 128000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.1.1.0 0.0.0.3 area 0
network 198.222.123.16 0.0.0.15 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 198.222.123.18
ISP:
interface Loopback0
ip address 209.165.200.225 255.255.255.224
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 198.222.123.18 255.255.255.240
ip address 10.5.5.2 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
network 10.5.5.0 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 Loopback0
Site 2:
interface Tunnel0
ip address 172.16.12.2 255.255.255.252
mtu 1476
tunnel source Serial0/0/1
tunnel destination 198.222.123.17
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
ip address 10.5.5.1 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
ip route 0.0.0.0 0.0.0.0 10.5.5.2
I'm fairly new to this, so I appreciate you taking the time to help.
-Stuart
rais
Level 7
Level 7
Did you ping 172.16.12.2 source 172.16.12.1?
Thanks.
rais
Level 7
Level 7
Thanks.
Ah, that's embarrassing! I was pinging the serial interface. It's working, thanks
