NAT port forwarding to Linux server with no gateway set.
sky-knight
I have a SR520 router which has a ADSL connection and I'm wondering if it is possible to configure the router so that a port can be forwarded to a Linux server that is on the same LAN network as the VLAN on the router without having a route/gateway setup on the Linux server.  If I set the router vlan IP address as the gateway on the Linux box then it works as expected and I can connect from a public IP to the local IP of the Linux server, but if I remove the gateway on the Linux computer, I can no longer connect, but since the LInux computer is on the same local network as the router it seems like it should be possible.
Below is the router config, I would like to be able to ftp from a public IP to 192.168.1.5 which is the local Linux box.  I know there can't be any outbound traffic from the Linux box without the gateway being set, but this is ok, or are routes a two way street and what I want can't be done? One thought I had was to use the remote command feature of ssh:
ssh <router-public-ip> 'ftp 192.168.1.5'
The problem with this is the router doesn't have a ftp command to connect to a ftp server.
version 12.4
no service pad
service password-encryption
hostname SR520
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
username cisco privilege 15 secret 5
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
  encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface FastEthernet0
switchport access vlan 75
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
shutdown
interface Vlan75
ip nat inside
ip virtual-reassembly
interface BVI1
ip address dhcp
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 atm0
no ip http server
no ip http secure-server
ip nat inside source list 100 interface BVI1 overload
ip nat inside source static tcp 192.168.1.5 21 interface BVI1 21
access-list 100 permit ip any any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
0 Replies 0
