NAT problem Destination nat
riz_432
hye all,
my problem is we have a setup something like this
externalserver--------RA---(OUTsideinterface)--RB(NATRouTeR)--(insideinterface)------ourWAN
here, static source routing is configured where some particular Wan pc's get their ip address natted to some global ip.Now the problem is can i nat the destination of these pc to some other ip address.the thing is our network uses different ip series than the one on the external server and we dont want to put those ip series routes in our wan. i've already tried ouside nat but that didn't do the job as it works if the packets are initiated from oustide interface(i.e the external server). Now is there a way out.
paddyxdoyle
Level 6
Level 6
Have your tried creating a static NAT containing the addresses you want to translate and then configure your inside interface as "ip nat outside" and your outside interface as "ip nat inside".
This should work
Paddy
hi paddy thnx for reply but the thing is there are some other nat translation that use the present inside and ouside interface configuration and if i change change inside and out side interface those wot work but my question in plain sense is IS destination(ie the destination ip of the packet initiated from the inside network users)nat possible for packets initiating(source) from the ip nat inside network.
