NAT problems on a L3 3650 switch
kmerentitis
So, I am trying to setup NAT on our new 3650 switch running IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.00E RELEASE SOFTWARE
This simple setup involves a layer 3 port (1/0/46) to our gateway and a Vlan for NAT
My hosts on my NAT Vlan (Vlan 2) do not seem able to ping anywhere else than the switch itself (all its interfaces) and their local subnet. Pings from the switch to outside are fine (NAT debug enabled):
Switch#ping 8.8.8.8 source 192.168.122.1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.122.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/66/70 ms
Switch#
*Nov 10 14:27:04.145: NAT: ICMP id=1->1025
*Nov 10 14:27:04.145: NAT: s=192.168.122.1->165.211.28.194, d=8.8.8.8 [5]
*Nov 10 14:27:04.210: NAT: ICMP id=1025->1
*Nov 10 14:27:04.210: NAT: s=8.8.8.8, d=165.211.28.194->192.168.122.1 [0]
Running Config:
! Last configuration change at 13:51:06 UTC Mon Nov 10 2014
version 15.2
no service pad
service compress-config
hostname Switch
boot-start-marker
boot system switch all flash:packages.conf
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
no aaa new-model
switch 1 provision ws-c3650-48ps
ip routing
ip dhcp excluded-address 192.168.122.1
ip dhcp pool Pool14
 import all
 network 192.168.122.0 255.255.255.0
 dns-server 165.211.29.1
 default-router 192.168.122.1
 domain-name my.domain
crypto pki trustpoint TP-self-signed-1875358754
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
 mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
 class non-client-nrt-class
  bandwidth remaining ratio 10
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
interface GigabitEthernet1/0/46
 description conf GW
 no switchport
 ip address 165.211.28.194 255.255.255.192
 ip nat outside
interface GigabitEthernet1/0/47
 switchport access vlan 2
 spanning-tree portfast
 spanning-tree bpduguard enable
interface GigabitEthernet1/0/48
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 ip address 192.168.122.1 255.255.255.0
 ip nat inside
ip nat inside source list 61 interface GigabitEthernet1/0/46 overload
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 165.211.28.193
access-list 61 permit 192.168.122.0 0.0.0.255
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
line vty 5 15
 login
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
I also tried using a Vlan (+nat outside) instead of the Layer3 port (1/0/46) with the same results
10 Replies 10
devils_advocate
Level 7
Level 7
Can you post results of the following:
#show ip route - On the switch
tracert -d 8.8.8.8 - On a host
Switch#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 165.211.28.193 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 165.211.28.193
      192.168.122.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.122.0/24 is directly connected, Vlan2
L        192.168.122.1/32 is directly connected, Vlan2
      165.211.28.0/24 is variably subnetted, 2 subnets, 2 masks
C        165.211.28.192/26 is directly connected, GigabitEthernet1/0/46
L        165.211.28.194/32 is directly connected, GigabitEthernet1/0/46
traceroute -n 8.8.8.8 (I am on a mac)
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
 1  192.168.122.1  2.546 ms  3.291 ms  2.104 ms
 2  * * *
 3  * * *
 4  *
Did you get this fixed? I'm having the exact same problem..
Thanks!
edited
I didn't manage to fix this. After digging into the documentation I found no sign about NAT support on the 3560 switch. I ended up using a router
NAT is not supported on any Catalyst switches except some very high end switches (and even then, the NAT support on those is limited).
If it works at all it will be processed switched (not in hardware) which will result in high CPU under any sort of load.  TAC will insist you remove it as these devices were not designed to do this function.
You really need a router to do NAT.  It's not a function of switching and has never been supported on these platforms, even if the CLI commands appear to exist.
Mukesh Kumar
Level 3
Level 3
Hello kmerentitis
Your configuration is looking correct. I have tested the same topology and its working. You have to check the ip address and default gateway on the host connected in vlan 2.
Mukesh Kumar
Network Engineer
Spooster IT Services
Thank u both for your help
The ip configuration should be correct as it retrieved from the dhcp server running on the switch.
I post the ip configuration from my (dhcp) client:
ip addr: 192.168.122.2
subnet mask: 255.255.255.0
router: 192.168.122.1
Hello 1) Can you confirm the public addressing is supposed to be static and is the subet mask correct? 2) Ip routing enabled? 3) sdm template being used? - sh sdm prefer res Paul
Kind Regards
Paul
Hello Paul,
1)yes the public addressing is correct. Our gateway is 165.211.28.193/26 and my public is setup 165.211.28.194/26.
2) Ip routing is enabled on the switch as you can see on my configuration
3)Switch#sh sdm prefer
Showing SDM Template Info
This is the Advanced (low scale) template.
  Number of VLANs:                                 4094
  Unicast MAC addresses:                           32768
  Overflow Unicast MAC addresses:                  512
  IGMP and Multicast groups:                       4096
  Overflow IGMP and Multicast groups:              512
  Directly connected routes:                       16384
  Indirect routes:                                 7680
  Security Access Control Entries:                 1536
  QoS Access Control Entries:                      3072
  Policy Based Routing ACEs:                       1024
  Netflow ACEs:                                    768
  Wireless Input Microflow policer ACEs:           256
  Wireless Output Microflow policer ACEs:          256
  Flow SPAN ACEs:                                  512
  Tunnels:                                         256
  Control Plane Entries:                           512
  Input Netflow flows:                             8192
  Output Netflow flows:                            16384
  SGT/DGT entries:                                 4096
  SGT/DGT Overflow entries:                        512
These numbers are typical for L2 and IPv4 features.
Some features such as IPv6, use up double the entry size;
so only half as many entries can be created.
