ā12-26-2014 12:06 AM - edited ā03-05-2019 12:26 AM
>>both routers are located in different countries and connected with ISP
>>IPsec over GRE tunnel is configured on both the routers
>>tunnel's line protocol is down for both the ends but able to reach the tunnel destination with tunnel source
>>Packet is not receiving on the router_1 and but could see packets are getting encrypting on the Router_2
>>ISP is not finding any issue with their end
>>Please guide me how i can fix this issue and what need to be check on this ????
Router_1#sh run int Tunnel20
Building configuration...
Current configuration : 272 bytes
interface Tunnel20
bandwidth 2048
ip address 3.85.129.141 255.255.255.252
ip mtu 1412
ip flow ingress
delay 1
cdp enable
tunnel source GigabitEthernet0/0/3
tunnel destination 109.224.62.26
end
Router_1#sh int Tunnel20
Tunnel20 is up, line protocol is up>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Keepalive is not set
Hardware is Tunnel
Description: *To CRPrgEIQbaghd01 - 2Mb GRE over Shared ISP Gateway*
Internet address is 3.85.129.141/30
MTU 17916 bytes, BW 2048 Kbit/sec, DLY 10 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 195.27.20.14 (GigabitEthernet0/0/3), destination 109.224.62.26
Tunnel Subblocks:
src-track:
Tunnel20 source tracking subblock associated with GigabitEthernet0/0/3
Set of tunnels with source GigabitEthernet0/0/3, 32 members (includes iterators), on interface <OK>
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1476 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input 1w6d, output 14w4d, output hang never
Last clearing of "show interface" counters 2y5w
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
1565172427 packets input, 363833090294 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1778491917 packets output, 1555959948508 bytes, 0 underruns
0 unknown protocol drops
Router_1#ping 109.224.62.26 re 100 sou 195.27.20.14
Sending 100, 100-byte ICMP Echos to 109.224.62.26, timeout is 2 seconds:
Packet sent with a source address of 195.27.20.14
Success rate is 92 percent (92/100), round-trip min/avg/max = 139/142/162 ms
Router_1#
Router_1#sh cry ip sa pe 109.224.62.26 | in caps
#pkts encaps: 831987306, #pkts encrypt: 831987306, #pkts digest: 831987306
#pkts decaps: 736012611, #pkts decrypt: 736012611, #pkts verify: 736012611
Router_1#sh clock
15:09:45.421 UTC Thu Dec 25 2014
Router_1#
#pkts encaps: 831987339, #pkts encrypt: 831987339, #pkts digest: 831987339
#pkts decaps: 736012611, #pkts decrypt: 736012611, #pkts verify: 736012611>>>>>>>>>>>>>>>>>>>>Traffic is not receiving from Router 2
Router_1#sh clock
15:11:36.476 UTC Thu Dec 25 2014
Router_1#
Router_2#sh run int Tu1
Current configuration : 269 bytes
interface Tunnel1
bandwidth 2000
ip address 3.85.129.142 255.255.255.252
ip mtu 1412
ip flow ingress
load-interval 30
keepalive 10 3
cdp enable
tunnel destination 195.27.20.14
end
Router_2#
Router_2#sh run | sec cry
crypto isakmp policy 10
authentication pre-share
crypto isakmp key Router_2 address 195.27.20.14
crypto isakmp key Router_2 address 194.9.241.8
crypto ipsec transform-set ge3vpn esp-3des esp-sha-hmac
mode transport
crypto map <Deleted> 10 ipsec-isakmp
set peer 195.27.20.14
set transform-set ge3vpn
match address Router_2
crypto map <Deleted> 20 ipsec-isakmp
set peer 194.9.241.8
match address Router_1
Router_2#
Router_2#sh cry ip sa pe 195.27.20.14 | in caps
#pkts encaps: 737092521, #pkts encrypt: 737092521, #pkts digest: 737092521
#pkts decaps: 828154572, #pkts decrypt: 828154572, #pkts verify: 828154572>>>>>>>>>>>>Traffic is getting encrypting from router 2
Router_2#sh clock
.15:10:33.296 UTC Thu Dec 25 2014
Router_2#
Router_2#sh int Tu1
Tunnel1 is up, line protocol is down>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Down
Hardware is Tunnel
Internet address is 3.85.129.142/30
MTU 17916 bytes, BW 2000 Kbit/sec, DLY 50000 usec,
Keepalive set (10 sec), retries 3
Tunnel source 109.224.62.26 (GigabitEthernet0/0), destination 195.27.20.14
Tunnel Subblocks:
src-track:
Tunnel1 source tracking subblock associated with GigabitEthernet0/0
Set of tunnels with source GigabitEthernet0/0, 2 members (includes iterators), on interface <OK>
Last input 1w6d, output 00:00:02, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 14843
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
1881547260 packets input, 956465296 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1705198723 packets output, 2654132592 bytes, 0 underruns
Router_2#ping 195.27.20.14 re 100 sou 109.224.62.26
Sending 100, 100-byte ICMP Echos to 195.27.20.14, timeout is 2 seconds:
Packet sent with a source address of 109.224.62.26
Success rate is 94 percent (94/100), round-trip min/avg/max = 136/143/164 ms
Router_2#
ā12-26-2014 11:40 AM
Hello.
First of all, try to reset IPSec (clear crypto isakmp sa ..., clear crypto session ...).
Configure inbound ACL on the router to match esp protocol and check if the packets arrive.
Please provide full output "show crypto ipsec sa"
from both sides.
