nat problems, please help
I need to connect to the server (pop3, smtp, remote) in the inside network using Public IP address.
I was trying :"IP NAT OUTSIDE SOURCE ... ... NO-ALIAS"
but it is not working. I can connect from outside, with no problems.
thanks,
mahmoodmkl
Level 7
Level 7
use
ip nat inside source static (inside ip address) (outside ip address)
Mahmood
i am using this, as i mentioned it is working fine from outside...
