NAT question
mjsully
Level 5
Level 5
This is probably a simple issue, but NAT seems to trip me up sometimes. On an IOS router, what is the config to make the inside address 10.10.1.1 leave the outside as 172.16.1.1 and I also need traffic coming into the outside interface destined for 172.16.1.2 to translate to 10.10.1.2
Help would be appreciated.
lgijssel
Level 11
Level 11
Hope that you will find the following link informative:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093f31.shtml#cfg_nat
The required commands are used in it and you can find other reference links in it too.
Leo
please, try
interface wan
ip nat out
ip nat source static 10.10.1.1 172.16.1.1
ip nat source static 10.10.2.2 172.16.1.2
interface lan
ip nat in
please rate this post.
Regards.
Thank you both!
