load-sharing vpn
lakn
Hi.
Running two 2621 routers and are having a couple of site-to-site vpns going through.
I am playing around with cef load-sharing on the serial interfaces but receives uneven loads on them.
Is it possible that it could be the vpns that concentrate on one of the lines only?
Is it possible to create load-sharing for the vpn also in the above case?
-- Lars
Richard Burts
Lars
Whether load sharing is possible depends a bit on what your topology is, and on how the VPNs are configured. In configuring the site to site VPN are you specifying a source address for the VPN packets, and if so what is it? What are you specifying as the peer address for the VPN and what does your routing table have for how to get to those addresses? If you have multiple paths to the VPN peer address (and if they have multiple paths back to you) then load sharing may be possible.
One of the assumptions in cef load sharing is that there would be multiple destinations and that traffic would generally be distributed accross those destinations. When you run a VPN it does make it look like a lot of traffic is going to a single destination and this would tend to bias the load sharing and put greater load on one of the links.
Rick
Rick
