NAT statements & SSH access
parkbenchit
Router is a recent C887VA running 15.3
When I have my NAT statements in place for ports 80 and 443, I have no external SSH access. It actively refuses my connection.
If I remove these 2 lines (154 and 155 in the attached txt file)
ip nat inside source static tcp 192.168.62.12 80 <WAN IP> 80 extendable
ip nat inside source static tcp 192.168.62.12 443 <WAN IP> 443 extendable
and reload, I have external SSH access. If I add them back, I still have external SSH access. If I then reload - no external SSH.
I don't lose internal (either from a device inside the LAN or if I come down the Tunnel) SSH at any point.
IP addresses don't change (router WAN, mine)
crypto key generate rsa has been done (and redone) - but as I always have internal SSH I don't think that's the issue.
I'm connecting using Putty and SSH1 preferred
2 questions:
a. What do I need to do to get permanent external SSH access?
b. More importantly - why? I thought I understood PAT & NAT - but clearly I'm missing something - if I could be pointed in the right direction of further reading - that'd be helpful.
Full (redacted) config is attached
These problems are typically related to the NAT overload that is configured:
ip nat inside source list 1 interface Dialer0 overload
Remove the above line and replace it with the following:
ip access-list extended NAT
 deny ip any 192.168.0.0 0.0.255.255
 permit ip 192.168.0.0 0.0.255.255 any
ip nat inside source list NAT interface Dialer0 overload
thanks for this - I've put this in place and rebooted - but with no change in behaviour
I suppose I could do this
ip nat inside source static tcp 192.168.62.1 22 interface [wan facing interface] 22
and then put an access list in place to restrict external SSH access to only IP's I trust
I understand why forwarding onto the internal interface should resolve - but I don't (yet) understand why implementing port-forwarding for 80&443 causes previously working SSH access to then refuse me.
Suggestions / pointers in the right direction would be most welcome...
thanks
