03-23-2011 04:55 AM - edited 03-04-2019 11:50 AM
Hi All,
I am currently trying to configure an ASA to NAT traffic from an outside interface thtrough a VPN tunnel.
The traffic is currently nat'd to an inside IP address on Site A. There is a VPN tunnel between Site A & Site B.
In Site A I have a subnet of 192.168.8.0/24 and a public web site. 192.168.8.5 is the ip address of the internal web server
Current entry on the ASA is
static (dmz,Outside) IPaddressofwebsite 192.168.8.5 netmask 255.255.255.255
In Site A I have a subnet of 192.168.10.0/24 and I want the traffic to be redirected to a new internal web server 192.168.10.5
so I changed the entry to
static (dmz,Outside) IPaddressofwebsite 192.168.10.5 netmask 255.255.255.255.
I get the error message in the syslogs that there is no route to 192.168.10.5 and I believe the issue is with the dmz part of the command above but I don't know which interface to put in there for the VPN - static (???,Outside) IPaddressofwebsite 192.168.10.5 netmask 255.255.255.255.
Can anyone tell me if is possible to NAT traffic coming from an outside interface through a point to point VNP tunnel to an IP address at the other side of teh tunnel?
Thanks in advance for you help.
JP
03-23-2011 09:12 AM
JP
it's not clear exactly what you are trying to do.
192.168.8.5 - presumably that is the DMZ on your site A firewall ?
192.168.10.5 - where does this reside in relation to the ASA ie. which interface does the ASA use to get to this network ?
If it is the inside interface then simply change the static to -
static (inside,outside) "publicIP" 192.168.10.5
basically whichever interface is used by the ASA to reach 192.168.10.5 is the interface to use in the static statement.
If i have misunderstood please explain further.
Jon
03-24-2011 04:12 AM
Hi Jon,
Thanks for the reply.
192.168.10.5 is in Site B which is connected to the ASA through a VPN tunnel. So in effect 192.168.10.5 is connected to the outside interface of Site A.
I dont think I will be able to get this configuration to work as I am effectivily trying to re-route traffic back out the interface the traffic came in on.
JP
