Load balance with EIGRP
charl
Hi I have problem with load balancing (per-destination)  across 2 x 2MB serial links, it only works from A-site to B-site, but not from B-site to A-site
The Eigrp ajacency is ok, but traffic is only using one link(Serial0/1/0) from B-site to A-site and not the other Serial 0/0/0.
Any Ideas ? See output bellow....
B-site-rtr#sh ip route 1.1.2.0 -> this is to the A-site
Routing entry for 1.1.2.0/22
  Known via "eigrp 2000", distance 90, metric 1762304, type internal
  Redistributing via eigrp 2000
  Last update from 1.1.2.50 on Serial0/1/0, 00:15:01 ago
  Routing Descriptor Blocks:
  * 1.1.2.50, from 1.1.2.50, 00:15:01 ago, via Serial0/1/0
      Route metric is 1762304, traffic share count is 1
      Total delay is 20020 microseconds, minimum bandwidth is 2048 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
      Loading 98/255, Hops 2
B-site-rtr#sh ip eigrp topology 1.1.2.0 255.255.252.0
EIGRP-IPv4 Topology Entry for AS(2000)/ID(1.1.4.5) for 1.1.2.0/22
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 1762304
  Descriptor Blocks:
  1.1.2.50 (Serial0/1/0), from 1.1.2.50, Send flag is 0x0
      Composite metric is (1762304/3072), route is Internal
      Vector metric:
        Minimum bandwidth is 2048 Kbit
        Reliability is 255/255
        Load is 98/255
        Minimum MTU is 1500
        Hop count is 2
  1.1.2.53 (Serial0/0/0), from 1.1.2.53, Send flag is 0x0
      Vector metric:
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 2
cadet alain
Can you do sh ip protocols | be eigrp on router B please
Regards.
Alain.
Hi Alain,  Here is the output bellow:
I see the Distance for the one link is 170 ? Not sure why this is caused ? - I guess this looks like un-equal cost  ?
B-rtr#sh ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "eigrp 2000"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Default networks flagged in outgoing updates
  Default networks accepted from incoming updates
  Redistributing: eigrp 2000
  EIGRP-IPv4 Protocol for AS(2000)
    Metric weight K1=1, K2=0, K3=1, K4=0, K5=0
    NSF-aware route hold timer is 240
    Router-ID: 1.1.4.5
    Topology : 0 (base)
      Active Timer: 3 min
      Distance: internal 90 external 170
      Maximum path: 4
      Maximum hopcount 100
      Maximum metric variance 1
  Automatic Summarization: disabled
  Maximum path: 4
  Routing for Networks:
    1.1.2.0/24
    1.2.1.0/28
  Routing Information Sources:
    Gateway         Distance      Last Update
    (this router)              90      1d00h
    1.1.2.50                      90      00:12:01 - > S0/0/1
    1.1.2.53                   170      00:11:12 - > S0/0/0
    172.25.101.2          90      00:11:12
    172.25.101.14         90      00:11:12
If I shut  the Serial that takes all the traffic to force traffic to Serial 0/0/0  I see :
B-rtr#sh ip route 1.1.2.0
  Known via "eigrp 2000", distance 170, metric 1762304, type internal
  Last update from 1.1.2.53 on Serial0/0/0, 00:02:48 ago
  * 1.1.2.53, from 1.1.2.53, 00:02:48 ago, via Serial0/0/0
      Loading 1/255, Hops 2
Looks like the second route is getting redistributed into EIGRP.. Is site A redisributing the routes from another Autonomous System?
Any idea if there are multiple AS involved.
If the route was redistributed the route would be external
I think the AD of  some advertised routes has been modified.
Could you do a sh run | be router ei, sh route-map , sh access-list
Regards.
Alain.
