11-17-2012 03:16 PM - edited 03-04-2019 06:10 PM
I am struggling with NAT translation on a Cisco router. I want to translate all HTTP traffic that exits my network to change the destination IP to 117.166.1.1 and translate the destination port from tcp 80 to tcp 3128.
i.e. If a PC with an IP 192.168.1.10 enters 200.1.1.1 into the webbrowser, instead of the traffic going to 200.1.1.1 on port 80, it will be directed to 117.166.1.1 on port 3128
This is because I am using a cloud url filter and want all HTTP traffic to go to that proxy.
I believe this can be done with an outside NAT but I am unable to get this work. Anyone know how to do this?
K
11-18-2012 08:41 AM
You didn't paste your config
your translation config should be like below
ip nat outside source static tcp 117.166.1.1 3128 200.1.1.1 80 add-route
Thank you
Raju
11-18-2012 12:53 PM
Hi Raju, I used 200.1.1.1 as one example but i am want to translate all traffic that has destination port 80.
Any idea how to do this?
11-22-2012 07:20 PM
Hi can anyone offer any other suggestions? Cheers
