NAT with ACL
greenplague
HI
How can I do a NAT and protect this with a acl?
for example, i have this rule
ip nat inside source static tcp 192.168.1.1 80 1.1.1.1 80
But I want that only IP 2.2.2.2 can access to the port 80, I can do this in the router?
Green
dmuinoorallo
Hello Greenplague,
I will need more information( could you put a network schema?), where is 2.2.2.2 in the same lan that 1.1.1.1? or in the same lan than 192.162.1.1?
this is the order of Nat-inside in cisco:
  • If IPSec then check input access list
  • decryption - for CET (Cisco Encryption Technology) or IPSec
  • check input access list
  • check input rate limits
  • input accounting
  • redirect to web cache
  • policy routing
  • routing
  • NAT inside to outside (local to global translation)
  • crypto (check map and mark for encryption)
  • check output access list
  • inspect (Context-based Access Control (CBAC))
  • TCP intercept
  • encryption
  • Queueing
if you want filter only 2.2.2.2 ip address you could check to put your ACL inside or outaside depending on your device (2.2.2.2) is
Hi dmuinoorallo,
The topology is simple, I attached an image
I have something like this:
ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.1 80 interface FastEthernet4 80
But I want that only IP 2.2.2.2 can access to the port 80, with no acl applied in the interface fastethernet4.
Thanks for the reply
Green
I think this will be your configuration:
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.252
ip nat inside
interface GigabitEthernet0/1
ip address 192.168.1.254 255.255.255.0 ===> "I don't know what is your ip in the router if your printer has 192.168.1.1"
ip nat outside
ip nat inside source list 100 interface Gi0/1 overload
access-list 100 remark Allowed IP NAT HOSTS
access-list 10 permit ip host 2.2.2.2 any eq 80 log
access-list 10 deny ip any any log
It will be working fine
Shouldn't that be:
ip nat outside
Since that interface is facing the cloud?
