NAT with route-map for a subnet
support
I am working on a VPN project in which we want to nat entire subnet to another one
I have worked for one-to-one nat in this scenario and following commnand works for that.
ip nat inside source static 192.168.2.196 10.140.68.1 route-map VPN-2-Remote ext
endable
But I can not do the same with the entire network. Can anyone suggest a solution.
I am using IOS 15.2.2
Claudion.com
rvarelac
Level 7
Level 7
Hi support@claudion.com
I think the following article will help you to accomplish this:
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14144-static.html
Hope it helps
-Randy-
