NAT with route-map
ohassairi
Level 5
Level 5
hello
i have the following scenario:
PC1 (192.168.1.1) + PC 2 (192.168.1.2) connected to sw
sw connected to outside interface of Router (192.168.1.254)
inside interface of router (172.20.70.254) connected to server 172.20.70.1
i need the router to make NAT only for traffic between PC1 and server
traffic between PC2 and server should be routed normally without NAT
i configured the following:
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
ip nat outside
interface FastEthernet1/0
ip address 172.20.70.254 255.255.255.0
ip nat inside
ip nat inside source static 172.20.70.1  10.79.1.1 route-map rm1
ip access-list extended acl1
deny ip host 172.20.70.1 host 192.168.1.2
permit ip host 172.20.70.1  host 192.168.1.1
route-map rm1 permit 10
match ip address acl1
when i ping from PC1 to 10.79.1.1 the router makes NAT (that's OK)
Pro Inside global Inside local Outside local Outside global
icmp 10.79.1.1:21582 172.20.70.1:21582 192.168.1.1:21582 192.168.1.1:21582
when i ping from PC2 to 10.79.1.1 the router makes also NAT (that's not OK. NAT should not happen)
icmp 10.79.1.1:44878 172.20.70.1:44878 192.168.1.2:44878 192.168.1.2:44878
can you help me understanding why this happen ?
actually, i found that :
will apply the route-map only for traffic coming to inside interface
so if server sends  traffic to 192.168.1.1 nat will happen but if the destination is 192.168.1.2 then no NAT
but when some one sends traffic to server from outside so the Route-map will not work by definition
balaji.bandi
not sure what is the below IP :
below simple NAT not working ? since you doing 1 to 1 NAT
ip nat inside source static 172.20.70.1 X.x.x.x ( should work right ?
or we missing some information here?
BB
10.79.1.1 is the NAT ip of internal server 172.20.70.1
ip nat inside source static 172.20.70.1 X.x.x.x  is not enough because it will make nat with both PCs
i need to make NAT only for traffic between PC1 and server, that's why i added route-map
