NAT
hugozidos
I configured NAT on my cisco 2811 router but after so many attempts to connect the internet , it failed. i configure the router to server as a DHCP server for different vlans. Tried and tried again but it didn't connect.
below are the configurations for both the switch and router:
ROUTER:
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.50
ip dhcp excluded-address 192.168.3.1 192.168.3.50
ip dhcp excluded-address 192.168.4.1 192.168.4.50
ip dhcp excluded-address 192.168.5.1 192.168.5.50
ip dhcp pool 2nd_floor
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   domain-name 2nd_floor
   dns-server 212.100.67.195 212.100.67.196
ip dhcp pool 3rd_floor
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   domain-name 3rd_floor
ip dhcp pool 4th_floor
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
   domain-name 4th_floor
ip dhcp pool 5th_floor
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   domain-name 5th_floor
interface FastEthernet0/0
 ip address 192.168.0.1 255.255.255.252
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/0.2
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
 no snmp trap link-status
interface FastEthernet0/0.3
 encapsulation dot1Q 3
 ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
 encapsulation dot1Q 4
 ip address 192.168.4.1 255.255.255.0
interface FastEthernet0/0.5
 encapsulation dot1Q 5
 ip address 192.168.5.1 255.255.255.0
interface FastEthernet0/1
 ip address 172.16.16.32 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
router eigrp 90
 network 172.16.16.0 0.0.0.255
 network 192.168.0.0 0.0.0.3
network 192.168.2.0
 network 192.168.3.0
 network 192.168.4.0
 network 192.168.5.0
 no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.16.1
ip http server
ip nat inside source list NOUN interface FastEthernet0/1 overload
ip access-list standard NOUN
 permit 192.168.0.0 0.0.0.255
 permit 192.168.2.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
SWITCH:
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
 switchport mode trunk
interface FastEthernet0/2
 switchport access vlan 2
 switchport mode access
interface FastEthernet0/3
 switchport access vlan 3
interface FastEthernet0/4
 switchport access vlan 4
interface FastEthernet0/5
 switchport access vlan 5
interface GigabitEthernet0/2
interface Vlan1
 ip address 192.168.0.2 255.255.255.252
 no ip route-cache
ip http server
line con 0
 exec-timeout 0 0
 password NOUN
 logging synchronous
 login
line vty 0 4
 exec-timeout 0 0
 password NOUN
 logging synchronous
 login
line vty 5 15
 login
Please i will appreciate any response, thanks.
Jon Marshall
Not sure why you have NAT setup for the 192.168.0.0/30 subnet as it only has the router and switch interface in it and your NAT acl doesn't match
However that is not the issue. I assume you need to NAT for the 192.168.2.0/24 clients in which case  you need to add "ip nat inside" under you fa0/0.2 subinterface.
Jon
Tinashe Ndhlovu
Just quickly glanced over the config and can u specify ip nat inside on all the inside interfaces you want to provide internet access to. The access list NOUN seems to only be covering the second floor and 192.168.0.1 if these are the only subnets you want to access the internet then cool, if more then change the access list NOUN to:
 permit 192.168.0.0 0.0.7.255
   (I think that's the WCM.. its been a while..)
ip nat inside
ip nat inside
ip nat inside
ip nat inside
Let me know how that goes
the corrections worked out perfectly, thanks alot.
Jon Marshall
Jon
thanks , made the corrections and it worked perfectly.
