Nating is not working
Amardeep Kumar
Cisco asa was running in my network. I powered it off and put another firewall ( Barracuda)  with same configuration same IP.
it was running perfectly. Now I have removed Barrcuda and power on cisco. But not natting from cisco is not working. servers are not accessible from outside.
Amar
Glad all working as expected, can we mark as solution here, if the issue resolved.
BB
9 Replies 9
balaji.bandi
Good, we would like to know - how are you configured ASA, what is the ASA model and Code running inside ASA.
Give us more information to understand your problem, there is always a solution, ASA tested many people tested and working ASA NAT.
So post below information :
1. Show run
2. show version
3. what is the IP address you try to nat, what is not working? going to the internet ?
BB
CiscoASA# sh run
: Saved
: Serial Number: JAD221009QY
: Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.8(2)
hostname CiscoASA
enable password $sha512$5000$f+kzIxcfeSQulmc3Dtv/jQ==$EH4AmR07iOkj2yXYoPnrYQ== pbkdf2
names
ip local pool remote-vpn 192.168.39.100-192.168.39.200 mask 255.255.255.0
ip local pool Remotebackup 192.168.37.100-192.168.37.200 mask 255.255.255.0
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 12.133.76.130 255.255.255.240
interface GigabitEthernet1/2
nameif outside2
security-level 0
ip address 50.192.171.25 255.255.255.248
interface GigabitEthernet1/3
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet1/4
bridge-group 1
nameif inside_3
security-level 100
interface GigabitEthernet1/5
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet1/6
bridge-group 1
nameif inside_5
security-level 100
interface GigabitEthernet1/7
description TestInterface
nameif inside7
security-level 100
ip address 192.168.8.254 255.255.255.0
interface GigabitEthernet1/8
nameif inside1
security-level 100
ip address 192.168.3.254 255.255.255.0
interface Management1/1
management-only
no nameif
no security-level
no ip address
interface BVI1
nameif inside
security-level 10
banner motd Welcome to Chetu Inc.
ftp mode passive
clock timezone GMT 0
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 4.2.2.2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network URbkupSVR-out
host 12.133.76.133
object network URbkupSVR-in
host 192.168.3.48
object network CRM-Svr-out
host 12.133.76.134
object network CRM-Svr-in
host 192.168.3.41
access-list 10 extended permit icmp any any echo-reply
access-list 10 extended permit icmp any any unreachable
access-list 10 extended permit icmp any any time-exceeded
access-list 10 extended permit tcp any object URbkupSVR-in eq 55415
access-list 10 extended permit tcp any object CRM-Svr-in eq www
access-list 10 extended permit tcp any object CRM-Svr-in eq https
access-list outside_cryptomap_4 extended permit ip object NETWORK_OBJ_192.168.3.0_24 object-group A186-All-floors+DMZ
access-list outside_cryptomap_4 extended permit ip object Plant-Network object India-VPNuser
access-list Plan-vpn_splitTunnelAcl standard permit 192.168.3.0 255.255.255.0
access-list Remote-Backup_splitTunnelAcl standard permit 192.168.3.0 255.255.255.0
access-list outside_cryptomap_1 extended permit ip 192.168.3.0 255.255.255.0 object Floor154
access-list outside_cryptomap_1 extended permit ip 192.168.3.0 255.255.255.0 object Floor154-FF
access-list outside_cryptomap_1 extended permit ip 192.168.3.0 255.255.255.0 object H06-LGF
access-list Newvpn_splitTunnelAcl standard permit 192.168.3.0 255.255.255.0
access-list outside_cryptomap extended permit ip 192.168.3.0 255.255.255.0 object NETWORK_OBJ_192.168.25.0_24
pager lines 24
logging asdm informational
mtu outside 1500
mtu outside2 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside7 1500
mtu inside1 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside1,outside) source static NETWORK_OBJ_192.168.3.0_24 NETWORK_OBJ_192.168.3.0_24 destination static NETWORK_OBJ_192.168.39.0_24 NETWORK_OBJ_192.168.39.0_24 no-proxy-arp route-lookup
nat (inside1,outside) source static NETWORK_OBJ_192.168.3.0_24 NETWORK_OBJ_192.168.3.0_24 destination static H06-LGF H06-LGF no-proxy-arp route-lookup
object network obj_any2
nat (inside_2,outside) dynamic interface
object network obj_any3
nat (inside_3,outside) dynamic interface
object network obj_any4
nat (inside_4,outside) dynamic interface
object network obj_any5
nat (inside_5,outside) dynamic interface
nat (inside1,outside) static URbkupSVR-out
object network Plant-Network
nat (inside1,outside) dynamic interface
nat (inside1,outside) static CRM-Svr-out
nat (inside1,outside2) after-auto source dynamic any interface
access-group 10 in interface outside
access-group 11 in interface outside2
route outside 0.0.0.0 0.0.0.0 12.133.76.129 1 track 100
route outside2 0.0.0.0 0.0.0.0 50.192.171.30 2
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 192.168.3.0 255.255.255.0 inside1
http 182.74.233.26 255.255.255.255 outside
http 192.168.8.0 255.255.255.0 inside7
http 182.74.233.26 255.255.255.255 outside2
http 103.42.91.34 255.255.255.255 outside
snmp-server host inside1 192.168.12.30 community ***** version 2c
snmp-server location Florida
snmp-server contact itsupport@chetu.com
snmp-server community *****
sla monitor 1
type echo protocol ipIcmpEcho 4.2.2.2 interface outside
num-packets 3
frequency 10
sla monitor schedule 1 life forever start-time now
service sw-reset-button
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec ikev2 ipsec-proposal India-2
protocol esp encryption aes-192 3des
protocol esp integrity sha-256 sha-1
class-map inspection_default
policy-map global_policy
class inspection_default
inspect icmp
inspect icmp error
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:2a7d878e2f9b4533e0bae777523b6604
: end
CiscoASA#
nattin not working
12.133.76.143 Public IP
192.168.3.41 local Ip
(config)# show version
Cisco Adaptive Security Appliance Software Version 9.8(2)
Firepower Extensible Operating System Version 2.2(2.52)
Device Manager Version 7.8(2)
Compiled on Sun 27-Aug-17 13:06 PDT by builders
System image file is "disk0:/asa982-lfbff-k8.SPA"
Config file at boot was "startup-config"
PlantationDataASA up 1 hour 34 mins
Internal ATA Compact Flash, 8000MB
BIOS Flash M25P64 @ 0xfed01000, 16384KB
Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1)
Number of accelerators: 1
have you tried to clear the NAT translations on the ASA ?
clear xlate
yes, I tried Xlate many times. but not working.
looking at your configuration, I don't see the network object 'NETWORK_OBJ_192.168.3.0_24' which is referenced in your access lists and your NAT statements. Try and add the below:
object network NETWORK_OBJ_192.168.3.0_24
subnet 192.168.3.0 255.255.255.0
nat (inside1, outside) dynamic interface
You have some inside interface, from which interface you are tried and not working.
As suggested @Georg Pauwen  you need to have match ip address in the group object for NAT to work.
change accordingly for each inside interface try and let us know.
BB
I did nothing. It started after some time itself.
Still known.
BTW thanks everyone for your time
Amardeep
BB
