NATing problem
shahid_duet
Dear Boss
I have cisco router in my side doing ipsec over VPN with another side. My router local interface is connected to local LAN and same as other side.
I need to access remote side server from my server connected to local LAN.
When i ping to remote server from my sever without nat :
tunnel ok,crypto ok, ospf ok, all are ok.
When i ping to remote server from my sever doing  nat :
Tunnel ok, crypto ok, ospf ok but no ping reply.
my configuration is:
interface tunnel 2
ip nat outside
interface Local
ip add 192.168.7.1 255.255.255.0
ip ant inside
Ip nat inside source static 192.168.7.31 172.30.30.1
Router#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
--- 172.30.30.1        192.168.7.31       ---                ---
What can i do now ? Pls help me .
Thankin You
shahid
Print output of sh ip route 172.30.30.1 in the remore router
Two things i world like you to do
1>remove ip nat outside from  interface GigabitEthernet0
2>and add a static route like
ip route 172.30.30.1 255.255.255.255 gig  1 tag 100
router ospf 88
redistribute static subnet tag 100
Report me back pls post done
11 Replies 11
blau grana
Level 7
Level 7
You provided too little information to help you, so we can only guess.
If everything is working withouot NAT and with NAT you are not able to reach remote site I would suggest:
- deb ip icmp on remote site if icmp request will be received, check src and dst IPs
- my guess is that there can be problem with routing - remote site can know about 192.168.7.0/24 so icmp reply can be delivered, but with NAT, icmp request will come with src IP 172.30.30.1 -> check remote site if there is correct route in routing table for this network.
Best Regards Please rate all helpful posts and close solved questions
hi blau
Your guess isok.
Remote site is out of my control.
1. when i ping to 172.30.30.1 from my pc 192.168.7.31 no reply.  why  ???
2. when i set local interface as 172.30.30.2 and pc 172.30.30.1, I get reply form remote server and all ok means no routing issue at remote site ????
i think issue is no 1.
pls suggest
shahid
If you could post some picture of your topology, it would be helpful. I do not know where 172.30.30/24 network lies.
It still could be routing issue:
- in first case source and destination IPs are not on same subnet, so routing must be involved.
- in second case src and dst IPs are on same subnet, so routing is eliminated
Best Regards
Please rate helpful posts
my terget is:
1. need to get 10.0.0.5 from 192.168.7.31
2. 10.0.0.5 need to get 192.168.7.31,but i need to nat 192.168.7.31 to 172.30.30.1 as i want to hide my local server IP.
i can not get 172.30.30.1 and 10.0.0.5  from 192.168.7.31 after nating.
plz help
It looks like very simple scenario.
my site router
int gi0/0
ip nat outside
int gi0/4
ip nat inside
ip nat inside source route-map MAP_NAT interface gi0/0
route-map MAP_NAT permit 10
match ip address NAT_ACL
ip access-list extended NAT_ACL
permit ip 192.168.7.0 0.0.0.255 10.0.0.0 0.0.0.255
deny   ip any any
you can customize ACL as you need, basicaly entire packet with source IP from 192.168.7.0/24 to 10.0.0.0/24 will be translated to IP of interface gi0/0.
This means that remote router should know this network (I assume from topology that both routers are directly connected and are on same subnet).
Make sure that server 10.0.0.5 has correctly set up gateway to route unknown traffic to remote router.
Best Regards
its acutally simple. but  ?????. all ur assumption is ok.
i dont understant the nat :
in fact, when i use ur configuration, no nat shows in show ip nat tr.
Shahid
Chk for reverse route for 172.30.30.X in your Remote site Router. How this route is getting advertised in OSPF.Do U have any Loopback created for this network/IP adress.Appreciate if you can paste the configs of both ends .Its should not be that much Complicated
Hi  nandi
Here are my config:
interface Tunnel3205
description ## B..........##
ip address 172.28.3.34 255.255.255.252
ip ospf message-digest-key 88 md5 nnnnnnnn
ip ospf cost 1
ip nat outside
tunnel source 172.29.97.16
tunnel destination 172.29.97.1
interface gi 1
  ip address 192.168.7.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
description Bnnnn_WAN_interface
ip address 172.29.97.16 255.255.255.224
ip nat outside
duplex auto
speed auto
crypto map bdcom-VPN
         router ospf 88
area 0 authentication message-digest
network 172.28.3.32 0.0.0.3 area 0
network 172.29.97.0 0.0.0.31 area 0
network 172.30.30.0 0.0.0.7 area 0
ip nat inside source static 192.168.7.31 172.30.30.1
ip access-list extended BB-nnnnnnnn
permit gre host 172.29.97.16 host 172.29.97.1
permit gre host 172.30.30.1 host 10.210.1.8
** how i check my loopback network ??? may be a problem in loobpack.
Thanking You
router ospf 88
hi nandi
u r great !!!!!
it ok.
thanks
shahid
:-) Happy it worked for you .
