NATing with two Internet Connection
s.nasheet
Hi ,
I need to configure Cisco 1841 which has two internet connection ( SDSL & ADSL2+) and want to distrubute traffic across  both links equally( Possiblly voice traffic to SDSL). One conection is already up and running and doing NAT  Overload  and now second connection need to be added to config.
Do I just need to add a one more default route towards the 2nd internet connection ( Dialer interface)? like 0.0.0.0 0.0.0.0. Dailer1
Here is the current config. ( only NAT config)
interface FastEthernet0/0
description *****LAN Connection to Switch*****
ip address 10.0.0.254 255.255.0.0
ip nat inside
ip virtual-reassembly
duplex auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
no snmp trap link-status
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer0
ip address negotiated
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
access list 5 10 permit 10.0.0.0 0.0.255.255
ip nat inside source list 5 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
Any sample config will really help.
Jon Marshall
s.nasheet wrote:
Hi ,
ip nat inside
duplex auto
interface ATM0/0/0
no ip address
pvc 0/38
interface Dialer0
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
Yes, just add a second default route pointing out of Dialer1. Also make suer you configure a similiar NAT statement ie.
int dialer
ip nat outside
ip nat inside source list 5 interface Dialer1 overload
Jon
Jon Marshall
s.nasheet wrote:
Hi ,
ip nat inside
duplex auto
interface ATM0/0/0
no ip address
pvc 0/38
interface Dialer0
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
int dialer
ip nat outside
Jon
Many Thanks Jon. I will try that first thing Monday morning.
