NATproblem
Wouter De Prins
Frequent Visitor
Frequent Visitor
Hi all,
I've a small problem with NAT. I have a Cisco1861 and that's connected to my ISP's modem via FE0/0. I can ping my intern network without any problem but the NAT isn't working so I can't connect to the internet.
Can somebody check what I've did wrong? Hereby the config:
Many thanks for the help!
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.2.255
ip dhcp excluded-address 192.168.3.255
ip dhcp excluded-address 192.168.2.10
ip dhcp pool INTERN
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1 255.255.255.0
   dns-server 8.8.8.8
ip dhcp pool GUEST
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1 255.255.255.0
   dns-server 8.8.8.8
no ipv6 cef
voice-card 0
license udi pid C1861W-SRST-C-F/K9 sn FGL153422S3
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
switchport mode trunk
interface FastEthernet0/1/2
interface FastEthernet0/1/3
switchport access vlan 2
spanning-tree portfast
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip nat enable
interface Vlan3
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip nat enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
access-list 1 permit 192.168.0.0 0.0.255.255
cadet alain
you should take this off:
as your f0/0 interface gets an IP address by DHCP it should also get a default gateway, verify this after deleting the default static route you entered  with sh ip route static command.
Regards.
Alain
cadet alain
Regards.
Alain
Perfect, that was it! Thank you very much!
