Natting in LAB
CSCO10758684
Hai all,
Sorry to ask very basic quiestin ...how implement natting in LAB ..if i ve two router in labs how can i perform the same ...it wud be better if some one cud pase the config
Pls forgive if this is rubbish quistion
Thanks in advance
Lijesh.N.c
royalblues
Level 10
Level 10
Lets consider a topology like this
loopback R1 Serial -- serial R2
loopback - 20.20.20.1/24
R1 serial - 10.10.10.1/24
R2 serial - 10.10.10.2/24
R1 config
interface Loopback1
ip address 20.20.20.1 255.255.255.0
ip nat inside
interface serial 2/0
ip address 10.10.10.1 255.255.255.0
ip nat outside
ip nat inside source static 20.20.20.1 interface serial 2/0
R2
interface s2/0
ip address 10.10.10.2 255.255.255.0
clock rate 64000
Now ping the serial interface of R2 from R1 sourcing from loopback1
ping 10.10.10.2 source loopback1
You should see the response even though you do not have a route for the loopback from R2
To verify the NAT, do a sh ip nat translations and you should see something like this
R1#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 10.10.10.1:1 20.20.20.1:1 10.10.10.2:1 10.10.10.2:1
--- 10.10.10.1 20.20.20.1 --- ---
The serial connection between the routers cn be substituted with an ethernet connection if you have the required interfaces
Narayan
royalblues
Level 10
Level 10
R1 config
interface Loopback1
ip nat inside
ip nat outside
R2
interface s2/0
clock rate 64000
Narayan
Hai Narayan,
Thanks alot for the same surey i am going to exicute the same ....thanks one again ..
i had spoken to you hope you rem.
you mean to say i can use eth interface instead of serial ..right ..
Lijesh.N.C
Airtel Blr
