Natting LAB (http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&for
CSCO10758684
Hai,
I was goin tru the notes (http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbee68c/0#selected_message)
i had tried to config the same but giving the error message
R2(config-if)#ip nat inside
*Mar 1 00:58:01.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan
ged state to up
% NBAR ERROR: parsing stopped
% NBAR Error : Activation failed due to insufficient dynamic memory
% NBAR Error: Stile could not add protocol node
%NAT: Error activating CNBAR on the interface Loopback1
R2(config-if)#
R2(config-if)#
*Mar 1 00:58:06.131: %SYS-2-MALLOCFAIL: Memory allocation of 10260 bytes failed
from 0x813AD218, alignment 0
Pool: Processor Free: 25548 Cause: Memory fragmentation
Alternate Pool: I/O Free: 9712 Cause: Not enough free memory
-Process= "Exec", ipl= 0, pid= 3, -Traceback= 0x8082C268 0x8000A2C4 0x80011ACC
0x81AF96AC 0x813AD21C 0x813AD39C 0x8138BD6C 0x8138BC00 0x8138BC2C 0x8138BC2C 0x
8138BC2C 0x8138BC4C 0x8138C634 0x81389880 0x81389924 0x813899AC
*Mar 1 00:58:06.135: %NBAR-2-NOMEMORY: No memory available for StILE lmalloc,
-Traceback= 0x8082C268 0x813AD24C 0x813AD39C 0x8138BD6C 0x8138BC00 0x8138BC2C 0x
8138BC2C 0x8138BC2C 0x8138BC4C 0x8138C634 0x81389880 0x81389924 0x813899AC 0x813
C12A8 0x813CF9E0 0x813B8D00
is this the problem with insufficiant router memory ..i using 2 1700 series router
can some one help on this
Lijesh.N.C
26 Replies 26
Lijesh.N.C
The DRAM requirement for c1700-advsecurityk9-mz.124-11.T.bin is 96MB DRAM and you only have 64MB DRAM.
The following image should fit your router
c1700-advsecurityk9-mz.124-21.bin
HTH,
__
Edison.
Please rate helpful posts
Hai Edison,
Wah ....great ,,,, thanks alot ..that was a valiable one ....great once again thanks ..let me try using
Lijesh.N.C
Lijesh.N.C
Please let us know how it works out and mark the thread as resolved if the recommendation fixed your problem.
__
Edison.
Hai Edison,
Thanks once again ..will do ASAP
Lijesh.N.C
Hai Edison,
I am trying to rate this post i am not able to do ...i am so sorry ... dont knw what is happening ...when i am submitting it not taking ... this has resolved my issue ... let me keep on trying ..
thanks a lot once again
THEN i was right when i said in the begining u need to change the ios image !!
cool at least it worked for u now espeacilly with very nice help from Edison
hai Marwi,
Thanks a lot for ur help ... ..tooo ....(appolze the late reply )
Lijesh.N.C
u welcome..
Please Rate the Helpful Posts
and good luck
hai Marwi,
I am trying to rate the post but not taking any one is facing the same issue .???????
Lijesh.N.C
Hai Edison,
Ihd been trying to rate for your reply cz it hd solvd my issu ...but unfrtnatly it not taking
MY RATING FOR YOU 5 +
Thanks a lot
Lijesh
hai
THanks marvi i am not able to rate ..its not taking
My rating for you 5
Thanks a lot
Lijesh.N.C
