natting subnetted class C range on Sub-interfaces
alextapia
if you only have 2 router interfaces, and on one you divide by using subinterfaces, can you NAT from one sub interface to another? They would all be tagged with 802.1Q vlan tags. assume 192.168.x.x IPs to be real, 10.x.x.x are private.
class C 192.168.0.0 /27
Something like this perhaps?:
interface Ethernet0/0
description connection to upstream ISP
ip address 192.168.102.98 255.255.255.252
no ip mroute-cache
full-duplex
interface Ethernet0/1
no ip address
no ip mroute-cache
full-duplex
interface Ethernet0/1.1
description STATIC ASSIGNMENTs to Customers on this vlan 192.168.0.1 - .30
encapsulation dot1Q 2
ip address 192.168.0.1 255.255.255.224
no snmp trap link-status
interface Ethernet0/1.2
description Natted /27 subnet outside addresses this would be a NATPOOL encompassing all 30 addresses in this range
encapsulation dot1Q 3
ip address 192.168.0.33 255.255.255.224
ip nat outside
interface Ethernet0/1.3
description INSIDE address ranges to be natted
encapsulation dot1Q 4
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Ethernet0/1.4
encapsulation dot1Q 5
ip address 10.12.12.1 255.255.255.0
ip nat inside
interface Ethernet0/1.5
encapsulation dot1Q 6
ip address 10.15.15.1 255.255.255.0
ip nat inside
ip default-gateway 192.168.102.97
ip nat pool VLAN3NATPOOL 192.168.0.34 192.168.0.62 netmask 255.255.255.224
! This would only use 192.168.0.33 for all internal addresses, correct?
ip nat inside source list 20 interface Ethernet0/1.2 overload
! Would this be the correct, in order to use the entire range of IP's?
ip nat inside source list 40 pool VLAN3NATPOOL overload
ip nat inside source list 50 interface Ethernet0/1.2 overload
access-list 20 permit 10.10.10.0 0.0.0.255
access-list 40 permit 10.12.12.0 0.0.0.255
access-list 50 permit 10.15.15.0 0.0.0.255
Thanks!
this is from the CCO NAT Q&A:
Q. Can Cisco IOS NAT be applied to sub-interfaces?
A. Yes. Source and/or destination NAT translations can be applied to any interface or sub-interface having an IP address (including dialer interfaces).
HTH,
GP
Thanks! I've discovered that you also need to put the statement: ip nat outside to the other interface as well ( GE0/0 ) as the sub-interface.
