NBAR Filtering problem
k.a.clarke
IOS: 12.3(17)
I'm trying to restrict internet access for a subnet; only allowing access to specific sites (windows/virus updates etc) using nbar
I've had success blocking sites and allowing all others with the following:
class-map match-any url-blocking
match protocol http host "*microsoft.com*"
match protocol http host "*www.mcafee.com*"
match protocol http url "*microsoft.com*"
match protocol http url "*www.mcafee.com*"
policy-map mark-url-blocking-traffic
class url-blocking
set ip dscp 1
ip access 107
deny ip any any dscp 1
permit ip any any
interface fa 0/0.2 (Internal interface)
ip access-group 107 out
interface fa 0/1 (External interface)
service-policy input mark-url-blocking-traffic
This blocked access to *.microsoft.com and *.mcafee.com but allowed access to everything else, So I presumed that by changing the access list to:
permit ip any any dscp 1
permit udp any any eq domain
deny ip any any
Would allow sites matched within url-blocking and block everything else but this doesn't appear to be the case. All requests are being blocked by the deny ip any any rule.
Any help appreciated!
5 Replies 5
pkhatri
Level 11
Level 11
Can you change your ACL to:
permit udp any eq domain any
deny ip any any
Paresh
PS. pls rate posts that help
Thanks for the fast response.
The requests are still being blocked on the deny ip any any statement within the acl though.
mheusinger
Level 10
Level 10
I would try
match protocol dns
class url-blocking
set ip dscp 0
class class-default
drop
interface fa 0/1
and no ACL on the internal interface should be needed.
Hope this works for you.
Regards, Martin
Thanks for the response.
I'm unable to specify drop for class-default
'Drop cannot be configured in class-default'
fa0/1 serves as an external interface for a number of subnets, not all of which i would like to restrict.
sorry, you are right. But you could use:
class-map match-all RestTrafficDropped
match any
and
class RestTrafficDropped
drop
Hope this helps! Please rate all posts.
Regards, Martin
