NBAR just to monitor Web Sites
johnramz
I am just getting started on learning about QOS and I came accross NBAR.  I simply configured it with this line on a particular interface:
ip nbar protocol-discovery
Now I do 'show ip nbar protocol-discover' and I noticed most of the traffic is http and also some unknown traffic. I already know how to customize it to detect different ports, for example for RDP traffic:
ip nbar custom RDP dest tcp 3389
NOW, I just want to do the same with the http traffic by configuring a filter that will allow detect all traffic from "youtube" or "yahoo" for example. I do not want to DROP or BLOCK this traffic I just want to monitor it without even turrning ON QOS at this point.
John
I suppose you want an example with NBAR?
here it is:
class-map GOOGLE
match  protocol http host " google.com"
class-map YAHOO
match protocol http host "yahoo.com"
policy-map URL
class GOOGLE
class YAHOO
interface x/x
service-policy input URL
then a sh policy-map int fx/x will give you the statistics.
I added the protocol keyword I had missed in the config I posted, it won't work without it
Regards.
Alain.
Ce message a été modifié par: cadetalain
13 Replies 13
cadet alain
I think the best option is to use NetFlow and monitor on a host with a NetFlow collector but if you  want to use NBAR then you must use MQC with no action and you'll be able to count  traffic going to each site, you'll have to use the match http host command in your class-map.
Regards.
Alain.
Thanks  for your prompt reply. Could you provide an example?
here it is:
class-map GOOGLE
class-map YAHOO
policy-map URL
class GOOGLE
class YAHOO
interface x/x
Regards.
Alain.
johnramz
Thanks again for your prompt reply. One more question, where does NBAR come into play in this example?
Would that traffic also show under: sh ip nbar protocol-discovery , and be part of the output of that command?
Reason I ask is because NBAR gives a total for that last 5 minutes traffic with a breakdown. I was wondering if that trafffic would show in there
John
everytime you use match protocol this is NBAR which operates and here it is making deep packet inspection looking at fields in layers above 3.
NBAR protocol discovery will not filter http traffic per destination  url.
yes  but you can change  from 5 minutes to 30 sec min with this command under interface : load-interval
Regards.
Alain.
Thanks Alain. It does not seem to be working. Here is what I did. I just did "GOOGLE": That's the same interface where I have nbar configured. I posted below.
John
RTR#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
RTR(config)#class-map GOOGLE
RTR(config-cmap)#match protocol http host "google.com"
RTR(config-cmap)#exit
RTR(config)#policy-map URL
RTR(config-pmap)#class GOOGLE
RTR(config-pmap-c)#exit
RTR(config-pmap)#exit
RTR(config)#int fa0/1
RTR(config-if)#service-policy input URL
RTR(config-if)#load-interval ?
  <30-600>  Load interval delay in seconds
RTR(config-if)#load-interval 60
RTR#sh policy-map int fa0/1 input class GOOGLE
FastEthernet0/1
  Service-policy input: URL
    Class-map: GOOGLE (match-all)
      0 packets, 0 bytes
      1 minute offered rate 0 bps
      Match: protocol http host "google.com"
FastEthernet0/1
      0 packets, 0 bytes
    Class-map: class-default (match-any)
      8958 packets, 2137793 bytes
      1 minute offered rate 6000 bps, drop rate 0 bps
      Match: any
RTR# sh run
interface FastEthernet0/1
ip address x.x.x.210 255.255.255.240
ip nat outside
ip virtual-reassembly
load-interval 60
duplex auto
speed auto
As this is WAN interface then the policy-map must be applied outbound
Regards.
Alain.
Would you mind providing more detail and outline the commands to accomplish it? . Apologize for being newbie
John
No problem.
int f0/1
no service-policy input URL
service-policy output URL
Regards.
Alain.
Alain,
something might be stopping this from working.  I made the change but no joy
John
FastEthernet0/1
  Service-policy output: URL
      0 packets, 0 bytes
      10098 packets, 2853593 bytes
      1 minute offered rate 3000 bps, drop rate 0 bps
      Match: any
ip address x.x.x..210 255.255.255.240
ip nat outside
load-interval 60
duplex auto
speed auto
hi,
just to test could you do this:
class-map test
match protocol icmp
policy-map test
int f0/1
no service-policy out URL
service-policy out test
then ping 8.8.8.8 from a host and do sh policy-map test int f0/1
if you've got matches then remove this policy-map from interface and reapply the one for http and from a web browser go to google.com and look at interface again to see if you've got matches.
Regards.
Alain.
Alain,
Thanks for sticking with me. I figured out. I did test it with the icmp and it worked fine. The correction I made was:
*google.com*  instead of  "google.com" . Actually I did *google* so that any traffic containing that word will be filtered. Then IOS adds the quotes anyway.
Thanks for your help . The only question I have standing in case you know is how to clear the counter for those packets and bytes back to "0" without removing and re-adding "service-policy out URL"?
John
FastEthernet0/1
      85 packets, 64823 bytes
      1 minute offered rate 7000 bps
      Match: protocol http host "*google*"
      3279 packets, 682644 bytes
      1 minute offered rate 17000 bps, drop rate 0 bps
      Match: any
To reset counters: clear counters command
Regards.
Alain.
