NBAR Newbie
angel-moon
Level 3
Level 3
Hello Everyone,
does anyone have a comprehensive list of custom settings for NBAR V6 that will block most P2P traffic.  The built in list seems incomplete.  Either that or a way to better block P2P traffic at the router level.
Thanks in advance.  All replies rated.
Marwan ALshawi
Although you can block p2p on the router but the application layer blocking is limited on the router may a firewall better to
Some extent buy the best way for this
Type of filtering us to use s proxy server with web filtering
So with the router nbar works on l7 and you can
Monitor ur network and c which p2p is being used and create a custom nbar class to block it
Also try to use zine based firewall on ur router which gives u more flexible
policies
Wish this helps
If helpful rate
