channelized HWICs for clear channel T1's
scottosan
More specifically, I have a few sites that have full clear channel T1's that will be upgraded to bonded multilink T1's. I have typically done this with (2) WIC-1DSUT1 cards.  Instead of using  2 cards in the new ones can I use a VWIC2-2MFT-T1/E1?  I am a little confused if you can used channelized cars on clear channel circuits.
paolo bevilacqua
Yes, you can. For clear channel and scalability, you can also use HWIC-4T1/E1
