NBMA ip address
B@B@r
hello everyone,
i am studying DMVPN  mgre, it was mentioned that physical interface of tunnel should have NBMA ip address.
or tunnel source address should be NBMA address??
what it mean ?
how can we find an ip address a NBMA address??
do you mean the tunnel source ? This is usually the IP address of the outgoing interface. What do you mean with NBMA (or do you mean NHRP) ?
Have a look at the sample config below, which IP address are you referring to ?
https://supportforums.cisco.com/t5/security-documents/dmvpn-with-configuration-example/ta-p/3145736
