NCS540 (IOS-XR) -- DHCP reservation
whistleblower14
is it possible to configure a static IP reservation on a NCS?
I`m not able to find a helpful documentation...
balaji.bandi
what i understand here, you looking NCS act as DHCP Server and reserve the static IP reservation to client ?
if that is correct - please check below document some guide lines and limitration
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/ipaddress/73x/b-ip-addresses-cg-73x-ncs540/m-implementing-dhcp-ncs5xx.html#concept_fvh_2wn_cdb
BB
M02@rt37
Hello @whistleblower14,
NCS run IOS-XR.
Find here official doc: https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/ip-addresses/72x/b-ip-addresses-cg-ncs5500-72x/m-implementing-dhcp-dnx-family.html
Best regards
whistleblower14
thank you @balaji.bandi and M02@rt37 !
I´ve found those documentation already too but in both of them, I did`nt found the part when it comes to the Client-Identifier which would be needed to match the "MAC-Address" from the affected device?! Either I missed it or it isn't listed...
