[ncs540] Please explain slow-tracking
sjrcoel
I wonder what kind of
slow-tracking
technology is used by
ncs540
Below is an example. Please refer to it when explaining
configure terminal
ptp
servo-slow-tracking 16
show configuration
commit
M02@rt37
Hello @sjrcoel,
The configuration you've provided is related to Precision Time Protocol
PTP
specifically the
servo-slow-tracking
feature on a Cisco NCS540 router.
PTP
is a protocol used for synchronizing the time across network devices with high precision.
Servo-slow-tracking
is a mechanism that allows a
PTP
device to make gradual adjustments to its clock, avoiding sudden or large changes. This is important in cases where maintaining time synchronization is critical, and abrupt changes could cause issues in the network.
You're configuration in details:
ptp
This command is used to enter the
PTP
configuration mode, where you can configure various
PTP
related settings.
This command configures the
servo-slow-tracking
feature with a value of 16. This value represents the number of
PTP
servo seconds it takes for the clock to gradually adjust or "track" any discrepancies. In other words, if there is a time synchronization error, the clock will make gradual adjustments over a period of 16
PTP servo seconds
to minimize abrupt changes in time.
In this context,
servo-slow-tracking
is a mechanism that helps ensure that time synchronization adjustments are made gradually and smoothly, rather than making sudden and potentially disruptive changes to the system clock. The value "16" represents the time period over which these adjustments occur.
Best regards
Torbjørn
PTP slow tracking
defines that the servo(servo clock algorithm) should correct the phase offset based on the number of nanoseconds defined, instead of reacting immediately to any time offset it receives. You can read more about
PTP and slow tracking
here: https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/sysman/72x/b-system-management-cg-ncs5500-72x/b-system-management-cg-ncs5500-72x_chapter_01011.html#Cisco_Concept.dita_63a0fc6f-3627-4521-a446-2b1b7ad6b72c
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
M02@rt37
Hello @sjrcoel,
PTP
specifically the
servo-slow-tracking
PTP
Servo-slow-tracking
PTP
ptp
PTP
PTP
related settings.
servo-slow-tracking
PTP
PTP servo seconds
In this context,
servo-slow-tracking
Best regards
