08-23-2011 08:55 PM - edited 03-04-2019 01:23 PM
Hello everybody,
We have built our network core with Juniper EX8216. But Juniper works terrible and we facing big problem with that. So I'm looking for advice which device can be placed instead of Juniper EX8216.
I'll tell you what I'm looking for more detailed. I need some device which can care 80 XGe ports, basic secure features, advanced routing features and QoS such as LLQ or CBWRED.
Sincerely,
GRinch
Solved! Go to Solution.
08-23-2011 09:25 PM
you can go with 6500, 7600 or you might have a look at Cisco Nexus 7000
08-23-2011 09:25 PM
08-23-2011 09:44 PM
Thanks a lot. Nexus is what we need. I also wondering if 12816 is good enough?
We have 6500 already and I would like to implement somethhing new.
Sincerely,
GRinch
08-23-2011 10:04 PM
not sure what youmean by ;
"also wondering if 12816 is good enough?"
08-23-2011 10:20 PM
Could Cisco 12816 be used to reach my goals? =)
08-23-2011 10:31 PM
sorry i misunderstand the 12816
anyway the Cisco 12000 Series i believe is not designed to be used in the enterprise mainly for SP
i think Nexus can give high density of 1G and 10G interface with high speed forwarding and performance
08-23-2011 10:33 PM
Thanks once again.
-GRinch
