Need help for FTP Port Forwarding behind ASA
it_casino-f
Hi to all,
I am new in the cisco world but im trying my best to learn more ;-)
I want to setup an IIS FTP Server behind ASA, works fine in LAN but Im still not able to access it from outside, I've read lot of guides for the past 3-4 days
but still I didnt succed to make it. Dont know what Im doing wrong, hope I will find help here
here is the running conf from my ASA (it is not configured by me, only the ftp part (nat, network object..)
ASA Version 8.4(2)
hostname ciscoasa
enable password 9S9HjwYX3Cu6MYv/ encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
ddns update method DynDNS
ddns
interval maximum 0 0 30 0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
allow-ssc-mgmt
interface Vlan2
nameif outside
security-level 0
ip address 197.254.3.250 255.255.255.248
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 196.200.16.2
name-server 196.200.16.27
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Office_Network
subnet 10.1.2.0 255.255.255.0
object network Guests
subnet 10.1.4.0 255.255.255.0
object network Slot_Network
subnet 10.10.0.0 255.255.0.0
object network Surveillance
subnet 10.1.3.0 255.255.255.0
object network Switch_Mgmt
subnet 10.1.15.0 255.255.255.0
object network NETWORK_OBJ_172_20_254_0_24
subnet 172.20.254.0 255.255.255.0
object network Surveillance_Terminals
range 10.1.3.31 10.1.3.40
object network NETWORK_OBJ_10.1.3.0_24
object network Core_Switch
host 192.168.1.4
object network ASA_Outside
host 197.254.3.250
object network ASA_Inside
subnet 192.168.1.0 255.255.255.0
object network NETWORK_OBJ_172.29.254.0_24
subnet 172.29.254.0 255.255.255.0
object network NETWORK_OBJ_192.168.1.0_24
object network NETWORK_OBJ_192.168.12.0_27
subnet 192.168.12.0 255.255.255.224
object network IakosVPN
subnet 10.0.0.0 255.255.255.240
object network Iakos_Outside
host 82.131.211.54
host 82.131.211.54
object network ITM
host 10.1.2.8
object network FTP_Server
host 10.1.2.10
object-group network Casino_Allowed
description Allowed for Internet
network-object 192.168.1.0 255.255.255.0
network-object object Guests
network-object object Office_Network
network-object object Surveillance_Terminals
network-object object NETWORK_OBJ_172_20_254_0_24
network-object object Slot_Network
network-object object Switch_Mgmt
access-list Tunel1_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list Tunel1_splitTunnelAcl standard permit 10.1.2.0 255.255.255.0
access-list Tunel1_splitTunnelAcl standard permit 10.1.3.0 255.255.255.0
access-list Tunel1_splitTunnelAcl standard permit 10.1.4.0 255.255.255.0
access-list Tunel1_splitTunnelAcl standard permit 10.1.15.0 255.255.255.0
access-list Tunel1_splitTunnelAcl standard permit 10.10.0.0 255.255.0.0
access-list inside_access_in extended permit ip object-group Casino object NETWORK_OBJ_172_20_254_0_24
access-list inside_access_in extended permit ip object-group Casino_Allowed any
access-list outside_mpc extended permit ip any any
access-list global_mpc extended permit ip any any
access-list s-tunnel_splitTunnelAcl standard permit 10.1.3.0 255.255.255.0
access-list outside_cryptomap extended permit ip object ASA_Inside object IakosVPN
access-list k-tunnel_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list outside_access_in extended permit tcp any interface outside eq ftp
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_Pool 192.168.12.1-192.168.12.25 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic Casino_Allowed interface
nat (inside,inside) source dynamic any interface destination static Casino Casino inactive
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static NETWORK_OBJ_172.29.254.0_24 NETWORK_OBJ_172.29.254.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_192.168.12.0_27 NETWORK_OBJ_192.168.12.0_27 no-proxy-arp route-lookup
nat (outside,inside) source static any any destination static Slot_Network Slot_Network
nat (inside,outside) source static ASA_Inside ASA_Inside destination static IakosVPN IakosVPN no-proxy-arp route-lookup inactive
nat (inside,outside) static FTP_Server service tcp ftp ftp
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
router eigrp 100
network 192.168.1.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 197.254.3.249 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.1.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer 82.131.211.54
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map0 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map0 interface outside
crypto ca trustpoint ASDM_TrustPoint0
enrollment terminal
subject-name CN=ciscoasa
crl configure
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.1.0 255.255.255.0 inside
telnet 10.1.2.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
no vpn-addr-assign dhcp
dhcp-client update dns server both
dhcpd dns 196.200.16.2 196.200.16.27
dhcpd lease 691200
dhcpd auto_config outside
dhcpd option 33 ip 10.1.0.0 192.168.1.4
dhcpd address 192.168.1.5-192.168.1.132 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 78.41.115.242 prefer
ntp server 62.178.1.13
webvpn
enable outside
anyconnect image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
anyconnect enable
tunnel-group-list enable
tunnel-group-preference group-url
group-policy DfltGrpPolicy attributes
dns-server value 196.200.16.2 196.200.16.27
group-policy GroupPolicy_82.131.211.54 internal
group-policy GroupPolicy_82.131.211.54 attributes
vpn-tunnel-protocol ikev1 ikev2
group-policy k-tunnel internal
group-policy k-tunnel attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value k-tunnel_splitTunnelAcl
default-domain none
group-policy s-tunnel internal
group-policy s-tunnel attributes
wins-server none
dns-server value 8.8.8.8
split-tunnel-network-list value s-tunnel_splitTunnelAcl
default-domain none
username admin password NfoaTNzlDvQAugvm encrypted privilege 15
username admin attributes
service-type nas-prompt
username kflg password QMcOmsDwXsvazrlO encrypted
username slotadmin password N2hAEXC/1o9tVCBF encrypted
tunnel-group k-tunnel type remote-access
tunnel-group k-tunnel general-attributes
default-group-policy k-tunnel
tunnel-group k-tunnel ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group s-tunnel type remote-access
tunnel-group s-tunnel general-attributes
address-pool VPN_Pool
default-group-policy s-tunnel
tunnel-group s-tunnel ipsec-attributes
tunnel-group 82.131.211.54 type ipsec-l2l
tunnel-group 82.131.211.54 general-attributes
default-group-policy GroupPolicy_82.131.211.54
tunnel-group 82.131.211.54 ipsec-attributes
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
class-map outside-class
match access-list outside_mpc
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
policy-map outside-policy
class outside-class
  ips inline fail-open
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:e5ebf9096c9c2b753caeb3e5e1d335bc
: end
11 Replies 11
Abzal
Level 7
Level 7
Hi Kosta,
First of all you need for this one public IP address. I see you have subnet 197.254.3.250/29. Just choose one real IP from this subnet. For example let's choose 197.254.3.251. And from configuration I see your FTP server IP address is 10.1.2.10, please correct me if  I'm wrong.
static (inside, outside) tcp 197.254.3.251 ftp 10.1.2.10 ftp netmask 255.255.255.255
static (inside, outside) tcp 197.254.3.251 ftp-data 10.1.2.10 ftp-data netmask 255.255.255.255
You also you need to fix your outside to ACL:
access-list outside_access_in extended permit tcp any interface outside eq ftp-data
And refer this link
https://supportforums.cisco.com/docs/DOC-2053
Hope it will help.
Please rate helpful posts.
Best regards,
Abzal
Thanks for trying to help me!
Im getting this error when trying to create static route
This syntax of nat command has been deprecated.
what this means?
What is version of your ASA? This error appears when you try commands above I showed?
Best regards,
Abzal
ASA 8.4(2)
Yes on the first command im gettin this error
Ok, then try this one, change your FTP_Server object group:
host 10.1.2.10
nat (inside,outside) static 197.254.3.251 service tcp ftp ftp
Note. I assume that your FTP is 10.1.2.10 and real IP is 197.254.3.251.
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/nat_objects.html#wp1106703
Hope it will help.
Best regards,
Abzal
my outside interface is configured directly to the external ip (197.254.3.250)
I have reserver 5 ip's from the provider for me (197.254.3.249-197.254.3.254)
should I make the nat to another address or *250?
Yes, you need to choose another one any IP address from 197.254.3.251 - 197.254.3.254 range. Because .250 is your outside interface, .249 is ISPs interface's IP addresses. And map it to internal IP of FTP.
Abzal
Best regards,
Abzal
Good afternoon,
Im still not able to solve my problem, here is my running config this time.
Result of the command: "sh run"
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
ddns
interface Vlan1
nameif inside
security-level 100
allow-ssc-mgmt
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.1.4
host 197.254.3.250
host 82.131.211.54
host 10.1.2.10
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat (inside,outside) static 197.254.3.252 service tcp ftp ftp
router eigrp 100
http server enable
enrollment terminal
crl configure
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 691200
dhcpd enable inside
webvpn
enable outside
anyconnect enable
default-domain none
wins-server none
default-domain none
username timbatec password qYGb/8ZLEm0OZ3sj encrypted
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
class outside-class
Cryptochecksum:9923be0a8c78f03ad6dbd8a55f6784b5
: end
You need to fix this one from
but should be like this
host 10.1.2.10
Hope it will help.
Best regards,
Abzal
but after listing the object networks you can see that it is like that (without the nat part)
I executed exactly the commands you've type me
Do you have connectivity from ASA to Internet? If so, try to remove and rename it:
no object network FTP_Server
object network FTP_10_1_2_10
host 10.1.2.10
Best regards,
Abzal
