Need Help Forward IP public To Lan
tengkuriza
Hello All ...Iam new using cisco router 2600
i need help
i want to use dmz like adsl modem to direct ip public to ip lan like 180.15.22.x.x to ip lan 192.168.1.2 ( lrouter mikrotik )  outside to inside
so when i call ip public then forrward to mikrotik
does anybody help me ...
this is my cisco configuration ...iam sorry my english is bad
xxx#sh run
Building configuration...
Current configuration : 2054 bytes
version 12.2
hostname xxxxxx
enable password
ip subnet-zero
ip cef
interface Loopback0
description to Astinet_Telkom180
ip address 180.250.79.xx 255.255.255.248
ip nat outside
interface FastEthernet0/0
description connection to WAN Lokal ( IP domestik BGP telk*m )
ip address 192.168.240.xx 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description connection to WAN Global ( IP inter BGP telk*m )
ip address 192.168.230.xx 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet1/0
description connection to LAN
ip address 192.168.1.1 255.255.255.252
ip nat inside
duplex auto
speed auto
router bgp xxxx
no synchronization
bgp log-neighbor-changes
network 180.250.79.xx mask 255.255.255.248
network 192.168.230.xx mask 255.255.255.252
network 192.168.240.xx mask 255.255.255.252
timers bgp 20 60
neighbor 192.168.230.xx remote-as 17974
neighbor 192.168.240.xx remote-as 17974
no auto-summary
ip nat inside source list 1 interface Loopback0 overload
ip classless
ip route profile
ip route 192.168.0.0 255.255.255.0 192.168.1.2
ip route 192.168.10.0 255.255.255.0 192.168.1.2
ip route 192.168.12.0 255.255.255.0 192.168.1.2
ip route 192.168.14.0 255.255.255.0 192.168.1.2
ip route 192.168.15.0 255.255.255.0 192.168.1.2
ip route 192.168.16.0 255.255.255.0 192.168.1.2
ip route 192.168.17.0 255.255.255.0 192.168.1.2
ip route 192.168.254.0 255.255.255.0 192.168.1.2
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.1.0 0.0.0.3
access-list 1 permit 192.168.0.0 0.0.0.254
access-list 1 permit 192.168.12.0 0.0.0.254
access-list 1 permit 192.168.14.0 0.0.0.254
access-list 1 permit 192.168.15.0 0.0.0.254
access-list 1 permit 192.168.16.0 0.0.0.254
access-list 1 permit 192.168.17.0 0.0.0.254
access-list 1 permit 192.168.254.0 0.0.0.254
access-list 1 permit 192.168.10.0 0.0.0.254
line con 0
line aux 0
line vty 0 4
password xxxxx
login
thasnks before
blau grana
Level 7
Level 7
Hello Tengku,
It is really simple, you just need to configure static nat.
ip nat inside source static PRIVATE_IP PUBLIC_IP
When traffic for PUBLIC_IP come to router, it will be forwarded to PRIVATE_IP.
In your case:
PRIVATE_IP = 192.168.1.2
PUBLIC_IP = 180.15.22.x
Problem is, that I can not see this IP on your router, where is this IP?
On Loop0 you have configured subnet 180.250.79.xx/29, you can use one IP from this range as PUBLIC_IP.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Tengku,
In your case:
Best Regards
sorry i forgot to include public ip ...
yes corrcet ...
  public ip from my isp
180.250.79.225/29
Let me try your way .....thanks before
i have try use this config
and exelent ..
thank you very much ....
