Need help on 2921 router
SACHIN SHARMA
We have a cisco 2921 at a remote site ,when i type a command it takes 15 sec to show output .
i chekced the cpu processes -it is normal
very minimal config on the router.
i am accessing the router over mpls cloud.
any help why this is responding slowly.
9 Replies 9
John Blakley
What are your ping times to the router? You said when you type a command it's slow....what about typing in general? Can you post your config?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John,
please see the responses below
tying in general is at normal speed.
ping X.X.X.X
Pinging X.X.X.X with 32 bytes of data:
Reply from X.X.X.X: bytes=32 time=57ms TTL=252
Reply from X.X.X.X: bytes=32 time=47ms TTL=252
Reply from X.X.X.X: bytes=32 time=46ms TTL=252
Reply from X.X.X.X: bytes=32 time=51ms TTL=252
Ping statistics for X.X.X.X:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 46ms, Maximum = 57ms, Average = 50ms
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.01.28 00:50:35 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
MPLSRTR02#term le 0
MPLSRTR02#sh run
Building configuration...
Current configuration : 4046 bytes
! Last configuration change at 07:29:50 UTC Sun Jan 26 2014 by xxxx
! NVRAM config last updated at 08:46:01 UTC Sun Jan 26 2014 by xxxx
version 15.2
service password-encryption
hostname MPLSRTR02
boot-start-marker
boot-end-marker
enable secret 5 #############
no aaa new-model
no ipv6 cef
ip domain name #######
ip cef
key chain eigrpkey
key 1
  key-string 7 ######################
license udi pid CISCO2921/K9 sn XXXXXXXXXXX
username xxxx privilege 15 password 7 ###############
interface Loopback0
ip address X.X.X.X 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.29
encapsulation dot1Q 29
ip address X.X.X.X 255.255.255.252
interface GigabitEthernet0/1
description LAN #To Firewall#
ip address X.X.X.X 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
network X.X.X.X 0.0.0.7
redistribute bgp XXXX metric 10000 1000 255 1 1500
router bgp XXXX
bgp log-neighbor-changes
network X.X.X.X mask 255.255.255.0
network X.X.X.X mask 255.255.255.255
network X.X.X.X mask 255.255.255.248
neighbor X.X.X.X remote-as XXXX
neighbor X.X.X.X send-community both
neighbor X.X.X.X soft-reconfiguration inbound
neighbor X.X.X.X distribute-list 10 in
neighbor X.X.X.X route-map ATT-LOC-PREF_IN in
neighbor X.X.X.X route-map ATT_BGP_OUT out
ip forward-protocol nd
ip bgp-community new-format
ip community-list 1 permit XXXX:10
ip community-list 2 permit XXXX:10
ip community-list 3 permit XXXX:20
ip community-list 4 permit XXXX:20
ip community-list 5 permit XXXX:30
ip community-list 6 permit XXXX:30
ip community-list 7 permit XXXX:100 -
ip community-list 8 permit XXXX:100
ip community-list 9 permit XXXX:200 -
ip community-list 10 permit XXXX:200
ip community-list 11 permit XXXX:300
ip community-list 12 permit XXXX:300
ip community-list 13 permit XXXX:100 -
ip community-list 14 permit XXXX:200
ip community-list 15 permit XXXX:300
ip community-list 16 permit XXXX:10 -
ip community-list 17 permit XXXX:20
ip community-list 18 permit XXXX:40
ip community-list 19 permit XXXX:40
ip community-list 20 permit XXXX:40
ip community-list 21 permit XXXX:50 -
ip community-list 22 permit XXXX:50
ip community-list 23 permit XXXX0:60
ip community-list 24 permit XXXX:60 -
ip community-list 25 permit XXXX0:70
ip community-list 26 permit XXXX0:100
ip community-list 27 permit XXXX:70
ip community-list 28 permit XXXX:10
ip community-list 29 permit XXXX:20
no ip http server
no ip http secure-server
ip route X.X.X.X 255.255.255.0 X.X.X.X
ip prefix-list EBGP_ADVERTISE seq 10 permit X.X.X.X/24
ip prefix-list EBGP_ADVERTISE seq 20 permit X.X.X.X/24
ip prefix-list EBGP_ADVERTISE seq 30 permit X.X.X.X/29
access-list 10 deny   0.0.0.0
access-list 10 permit any
route-map ATT-LOC-PREF_IN permit 10
match community 7 9 13 16 21 24
set local-preference 400
route-map ATT-LOC-PREF_IN permit 20
route-map ATT_BGP_OUT permit 10
match ip address prefix-list EBGP_ADVERTISE
set community XXXX:10
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input all
line vty 5 15
privilege level 15
login local
transport input all
scheduler allocate 20000 1000
end
What commands are taking 15 seconds to show output for? I'm assuming that this is after you hit enter...
HTH,
John
any show command infact ,yes after hitting enter.
What version of IOS?
HTH,
John
Here it is
c2900-universalk9-mz.SPA.152-1.T4.bin
Thank You
Kalyan.
I can't find any bugs related to the version. Has this always been slow or just started? If it just started, I'd suggest a reload. Something may have created a memory leak that's causing the router to run slow.
HTH,
John
we have another router with exact same version of ios at the site  but on different mpls cloud and its response time is good.
is there any specific commands to investigate memory issues on the device.
Show proc mem will show you what's being used. I don't think the ISP has anything to do with this. The show commands are run locally on the router, and if your ping times and traffic seem fine, it's not a provider issue.
HTH,
John
