Cannot ping public ip address
Can anyone please help me on this? All internal routes are working but cannot ping outside the internet.
Strange things is the tunnel is UP. But the router cannot ping the modem or any public ip.
Here's the config on the router:
interface Tunnel65
description ipsec vti to sgsineqnix-gw-2
ip address 10.255.255.14 255.255.255.252
ip summary-address eigrp 89 10.160.0.0 255.255.224.0 5
tunnel source 177.244.222.58
tunnel destination 176.215.93.246
interface FastEthernet0/0
description ADSL WAN Interface
ip address 177.244.222.58 255.255.255.248
ip access-group firewall in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description internal
ip address 10.160.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
router eigrp 89
redistribute static
network 10.160.0.0 0.0.31.255
network 10.255.255.12 0.0.0.3
network 10.255.255.32 0.0.0.3
network 10.255.255.40 0.0.0.3
network 10.255.255.92 0.0.0.3
network 10.255.255.100 0.0.0.3
no auto-summary
ip route 0.0.0.0 0.0.0.0 177.244.222.57
ip route 10.160.0.0 255.255.224.0 10.160.1.254
no ip http server
ip nat translation tcp-timeout 42300
ip nat translation udp-timeout 150
ip nat translation finrst-timeout 45
ip nat translation syn-timeout 45
ip nat translation dns-timeout 45
ip nat translation icmp-timeout 45
ip nat translation max-entries 4000
ip nat pool nat 177.244.222.58 177.244.222.58 netmask 255.255.255.248
ip nat inside source route-map nat pool nat overload
ip access-list extended firewall
permit ip any host 177.244.222.58
permit ip any host 177.244.222.57
permit icmp any any
ip access-list extended nat
permit ip 10.160.0.0 0.0.31.255 any
route-map nat permit 10
match ip address nat
FastEthernet0/0            177.244.222.58  YES manual up                    up
FastEthernet0/1            10.160.1.1      YES NVRAM  up                    up
Serial0/3/0                10.252.160.2     YES NVRAM  down                  down
NVI0                       unassigned      NO  unset  up                    up
Tunnel61                   10.255.255.102  YES NVRAM  up                    up
Tunnel65                   10.255.255.14   YES NVRAM  up                    up
Tunnel152                  10.255.255.42   YES NVRAM  up                    up
Tunnel6301                 10.255.255.94   YES NVRAM  up                    up
Tunnel8601                 10.255.255.34   YES NVRAM  up                    up
Please have a look on my config and check if I'm missing something.
Jenna
16 Replies 16
I forgot to mention that the modem can ping public ip so I don't think the problem is the modem.
which subnets can't communicate with outside ? Can the 10.160.1.0/24  subnet go out and not others?
If so change your NAT ACL like this:
no 10
10 permit ip 10.0.0.0 0.255.255.255
Trell us if it solved the problem.
Alain
Hi Cadet,
The subent 10.160.0.0/19 and 10.160.1.0/24 cannot communicate with outside. Even the router cannot ping 4.2.2.2.
I tried to enter the config you gave but still no luck.
Jenna
What traffic is meant to go via the tunnel ?
Can you post full config of the router.
Jon
Hi Jon,
The inter-office traffic is meant to go via tunnels.
Here's the full-config:
Building configuration...
Current configuration : 3719 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname gw-1
boot-start-marker
boot system flash C2801-ipbase-mz.124-7a.bin
boot-end-marker
no aaa new-model
resource policy
ip cef
--More--         !
no ip dhcp use vrf connected
ip dhcp pool my-data
   network 10.160.3.0 255.255.255.0
   domain-name domain.net
   dns-server 10.65.20.4
   default-router 10.160.3.254
   lease 0 8
   class vlan30-range
      address range 10.160.3.30 10.160.3.223
ip dhcp class vlan30-range
ip dhcp class my-data
   relay agent information
      relay-information hex 0000000000000a3e03fe mask ffffffffffff00000000
ip domain name domain.net
ip name-server 203.121.65.65
login block-for 60 attempts 3 within 30
login delay 10
--More--         !
interface Tunnel61
description ipsec vti to aunsweqnix-gw-3
ip address 10.255.255.102 255.255.255.252
tunnel destination 176.215.109.14
interface Tunnel65
interface Tunnel152
description ipsec vti to hkhkgdcent-gw-1
ip address 10.255.255.42 255.255.255.252
--More--          tunnel source 177.244.222.58
tunnel destination 176.215.122.5
interface Tunnel6301
description ipsec vti to phmnlccent-gw-3
ip address 10.255.255.94 255.255.255.252
tunnel destination 176.215.104.4
interface Tunnel8601
description ipsec vti to cnshaccent-gw-3
ip address 10.255.255.34 255.255.255.252
tunnel destination 176.215.110.4
no ip redirects
no ip unreachables
--More--          no ip proxy-arp
ip nat outside
duplex auto
speed auto
no ip redirects
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface Serial0/3/0
bandwidth 1984
ip address 10.252.160.2 255.255.255.252
encapsulation ppp
fair-queue 64 256 256
router eigrp 89
--More--          network 10.255.255.32 0.0.0.3
no auto-summary
no ip http server
--More--          permit icmp any any
control-plane
Jenna
If you do a tracroute from a client what is it showing ?
Jon
Hi Jon,
Here's a tracerote from the switch:
sw-1# traceroute 4.2.2.2
traceroute to 4.2.2.2 ,
              1 hop min, 30 hops max, 5 sec. timeout, 3 probes
1 10.160.1.1             0 ms       0 ms       0 ms
2  *  *  *
3  *  *  *
4  *  *  *
5  *  *  *
6  *  *  *
7  *  *  *
8  *  *  *
9  *  *  *
Jenna
Can you ping 177.244.222.57 from the router and then post the output of "sh arp" from the router.
Jon
gw-1#ping 177.244.222.57
Sending 5, 100-byte ICMP Echos to 177.244.222.57, timeout is 2 seconds:
Success rate is 0 percent (0/5)
gw-1#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.160.1.254           12   0023.4797.6640  ARPA   FastEthernet0/1
Internet  10.160.1.1              -   0017.e023.c7ab  ARPA   FastEthernet0/1
Internet  177.244.222.58          -   0017.e023.c7aa  ARPA   FastEthernet0/0
Internet  177.244.222.57          0   c8d3.a3de.b846  ARPA   FastEthernet0/0
Jenna
Apologies for all the outputs requested. Can you post "sh ip route" from the router ?
Jon
show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 177.244.222.57 to network 0.0.0.0
     177.244.0.0/29 is subnetted, 1 subnets
C       177.244.222.56 is directly connected, FastEthernet0/0
     172.16.0.0/24 is subnetted, 4 subnets
D EX    172.16.28.0 [170/297247232] via 10.255.255.13, 05:30:08, Tunnel65
D EX    172.16.29.0 [170/297247232] via 10.255.255.13, 05:30:08, Tunnel65
D EX    172.16.24.0 [170/297247232] via 10.255.255.13, 05:30:08, Tunnel65
D EX    172.16.10.0 [170/297247232] via 10.255.255.13, 05:30:08, Tunnel65
     172.31.0.0/24 is subnetted, 1 subnets
D EX    172.31.31.0 [170/297246976] via 10.255.255.93, 05:13:39, Tunnel6301
     192.168.200.0/32 is subnetted, 1 subnets
D EX    192.168.200.3 [170/297246976] via 10.255.255.13, 05:30:08, Tunnel65
--More--              10.0.0.0/8 is variably subnetted, 54 subnets, 4 masks
C       10.255.255.12/30 is directly connected, Tunnel65
D       10.0.0.0/30 [90/297244672] via 10.255.255.13, 05:30:09, Tunnel65
D EX    10.1.0.0/16 [170/297246976] via 10.255.255.13, 05:30:09, Tunnel65
D       10.255.255.4/30 [90/310044416] via 10.255.255.13, 05:30:09, Tunnel65
D       10.0.0.4/30 [90/298526976] via 10.255.255.93, 10:30:37, Tunnel6301
D       10.255.255.28/30 [90/310044416] via 10.255.255.41, 05:15:34, Tunnel152
                         [90/310044416] via 10.255.255.33, 05:15:34, Tunnel8601
D       10.255.255.16/30 [90/310044416] via 10.255.255.41, 05:35:58, Tunnel152
                         [90/310044416] via 10.255.255.13, 05:35:58, Tunnel65
C       10.255.255.40/30 is directly connected, Tunnel152
D       10.255.255.44/30
           [90/299804416] via 10.255.255.93, 08:18:04, Tunnel6301
C       10.255.255.32/30 is directly connected, Tunnel8601
D       10.255.255.36/30
           [90/299804416] via 10.255.255.93, 08:18:07, Tunnel6301
D       10.63.0.0/19 [90/297246976] via 10.255.255.93, 05:13:39, Tunnel6301
D       10.255.255.60/30
           [90/299804416] via 10.255.255.93, 00:28:16, Tunnel6301
D       10.255.255.48/30
D       10.55.0.0/19 [90/298526976] via 10.255.255.93, 08:18:04, Tunnel6301
D       10.255.255.72/30
--More--                    [90/299804416] via 10.255.255.93, 05:14:50, Tunnel6301
D       10.255.255.76/30
D       10.66.0.0/19 [90/298526976] via 10.255.255.93, 10:30:37, Tunnel6301
D       10.255.255.64/30
           [90/298524416] via 10.255.255.93, 05:13:40, Tunnel6301
D       10.65.0.0/19 [90/297244672] via 10.255.255.13, 05:30:09, Tunnel65
D       10.255.255.68/30
D       10.255.255.88/30
C       10.255.255.92/30 is directly connected, Tunnel6301
D       10.82.0.0/19 [90/298526976] via 10.255.255.93, 05:14:50, Tunnel6301
D       10.255.255.80/30
           [90/299804416] via 10.255.255.93, 10:30:37, Tunnel6301
D       10.81.0.0/19 [90/298526976] via 10.255.255.93, 05:13:38, Tunnel6301
D       10.86.0.0/19 [90/297246976] via 10.255.255.33, 05:13:21, Tunnel8601
D       10.255.255.84/30
           [90/298524416] via 10.255.255.93, 00:28:25, Tunnel6301
D       10.255.255.104/30
           [90/310044416] via 10.255.255.33, 05:30:08, Tunnel8601
           [90/310044416] via 10.255.255.13, 05:30:08, Tunnel65
D       10.255.255.108/30
--More--                    [90/298524416] via 10.255.255.93, 05:15:33, Tunnel6301
D       10.255.255.96/30
           [90/298524416] via 10.255.255.93, 08:18:05, Tunnel6301
D EX    10.65.32.0/19 [170/310044416] via 10.255.255.13, 05:30:10, Tunnel65
C       10.255.255.100/30 is directly connected, Tunnel61
D       10.255.255.120/30
D       10.255.255.124/30
           [90/310044416] via 10.255.255.33, 05:13:21, Tunnel8601
D       10.255.255.112/30
D       10.255.255.116/30
           [90/299804416] via 10.255.255.93, 05:13:38, Tunnel6301
D       10.255.255.136/30
D       10.255.255.140/30
D       10.255.255.128/30
D       10.255.255.132/30
D       10.152.0.0/19 [90/297246976] via 10.255.255.41, 05:15:10, Tunnel152
D       10.255.255.144/30
--More--                    [90/299804416] via 10.255.255.93, 05:14:51, Tunnel6301
D EX    10.171.0.0/16 [170/297246976] via 10.255.255.13, 05:30:10, Tunnel65
D       10.255.255.160/30
S       10.160.0.0/19 [1/0] via 10.160.1.254
C       10.160.1.0/24 is directly connected, FastEthernet0/1
D       10.255.255.184/30
D       10.255.255.188/30
D       10.255.255.176/30
           [90/299804416] via 10.255.255.93, 00:28:17, Tunnel6301
D       10.255.255.180/30
D       10.61.224.0/19 [90/298526976] via 10.255.255.93, 10:30:37, Tunnel6301
D       10.255.255.248/30
           [90/297246976] via 10.255.255.41, 05:15:11, Tunnel152
D       10.255.255.252/30 [90/297247232] via 10.255.255.13, 05:30:10, Tunnel65
S*   0.0.0.0/0 [1/0] via 177.244.222.57
D EX 192.168.0.0/17 [170/297247232] via 10.255.255.13, 05:30:10, Tunnel65
Jon Marshall
Jenna
So the tunnels are up and you are receiving routes from the remote destinations, is that correct ?
I just tried tracerouting to your fa0/0 IP address and it stops after three hops only. I also cannot ping that IP.
Do you have any spare IPs from the 177.244.222.56/29 subnet ?
Jon
Hi Jon,
Yes, the tunnels are up and can access the router remotely.
We are only using 177.244.222.57 on the modem and .58 on this router.
Jenna
I am wondering if it is something to do with your NAT config. Is there any chance you could change the nat pool to use a spare IP from the public IPs instead of the fa0/0 interface IP you have and then tie that new NAT pool to your NAT statement.
You may need to clear any existing translations on your router.
It may not work but i think it is worth a try.
Jon
