need help on access list
kadam_abhijit1
Dear All,
I wanted to configure access list on cisco 2851 router. requesting you please help me.
Source :- 11.11.11.11/24
Destination :- 10.10.10.10
Port :- 7777
Thenks in advance.
Abhijit
5 Replies 5
Traian Bratescu
Assumptions:
* traffic is TCP
* only this traffic will be allowed inbound - interface fa0/0 in the example; everything else is denied
R3(config)#access-list 2001 permit tcp 11.11.11.0 0.0.0.255 host 10.10.10.10 eq 7777
R3(config)#int fa 0/0
R3(config-if)#ip access-group 2001 in
Traian
Thank you so much for the solution. will try and let you know. :)
Hello
Please note if you are running any routing protocol on the interface your appling the acl make sure you allow that protocol to transit
access-list 100 permit <eigrp | ospf> any any
access-list 100 permit udp any any eq rip
access-list 100 permit tcp any any eq bgp
access-list 100 permit tcp 11.11.11.0 0.0.0.255 10.10.10.0 0.0.0.255 eq 777
res
Paul
Kind Regards
Paul
Hello Friend,
First you have to configure the access-list then you have to apply it to the proper interface to take changes effect.
As said by Mr.Traian  u need to find whether the intresting traffic is TCP/UDP and configure the access-list to permit/deny. Then need to apply inbound/outbound accordingly to the interface for take the changes effect.
**access-list will take the sequential order to get executed, if you are not having permit command to any any or if you are not having enough commands to have your task done, then please note that there is always an explicit deny in the end.
Have a look here
http://www.cisco.com/c/en/us/support/docs/security/ios-firewall/23602-confaccesslists.html
http://computernetworkingnotes.com/network-security-access-lists-standards-and-extended/extended-access-list.html
http://orbit-computer-solutions.com/Access-Control-Lists--ACL-.php
Sanjith47
Please let us know whether you want to deny the traffic or permit it. Are both subnets on the same router or exists in different ones.
If on different then router 2851 hosts which subnet and on what port.
