Need help on deciding the part number for cisco fan tray
redindian
I have a switch with part number WS-C4006-S2 , and the fan tray for this switch is faulty, however,i do not know the part number for the fan tray, furthermore, i have found one fan tray's part number in cisco website, WS-X4005= with description :Catalyst 4006 Fan Tray (Spare);my question is i would like know whether WS-X4005= is the correct fan tray for WS-C4006-S2 .
purohit_810
Level 5
Level 5
You required for 4006, WS-C4006-S2
Catalyst 4000 Chassis (6-Slot), Suprvsr II,(2) AC PS, fans
For supervisore Engine-II.
Above is correct one.. WS-X4005 is for 4005 switch..
Dharmesh Purohit
IJAZDAR
Description: Catalyst                  4006 Chassis (6-Slot), Supervisor II, (2)AC Power Supplies, Fan                  Tray, Rack-Mount Kit
Part Number: WS-C4006-S2
Description: Catalyst                  4006 Fan Tray (Spare)
Part Number: WS-X4005=
Here is the link for the full list
Cisco Products Quick Reference Guide: February 2002
Chapter 2: LAN Switching
http://www.cisco.com/warp/public/752/qrg/cpqrg2.htm#73543
Hope this helps for any future queries for older equipment
