NEED HELP! PPTP CLIENT CANNOT CONNECT TO INTERNET WITH PPTP SERVER
Eric_Lee
Here's the setup:
Cisco ISR4221 router is to be configured as PPPoE/PPTP/L2TP Server.
One ethernet port (GigabitEthernet0/0/0) of the router is connected to the Internet source, while the second ethernet port (GigabitEthernet0/0/0) is connected to a switch that is also connected to 1 Windows computer that will be used as PPTP client.
My problems:
1. PPTP client can not connect to internet and show below error message on Cisco ISR4221 router.
.Jul 4 09:10:47.105: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to up
.Jul 4 09:10:47.106: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to up
.Jul 4 09:10:47.113: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access4, changed state to up
.Jul 4 09:10:47.116: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
.Jul 4 09:10:47.151: %FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x80007F58269BA6F0, ifnum= 17
There is the router config:
Building configuration...
Current configuration : 3684 bytes
! Last configuration change at 09:08:21 UTC Tue Jul 4 2023
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip dhcp excluded-address 192.168.99.150 192.168.99.200
ip dhcp excluded-address 192.168.150.150 192.168.150.200
ip dhcp pool pool99
network 192.168.99.0 255.255.255.0
default-router 192.168.99.1
dns-server 8.8.8.8 8.8.4.4
lease 0 1
no login on-success log
subscriber templating
ipv6 unicast-routing
ipv6 dhcp pool pool2222
prefix-delegation pool ForLanPC
address prefix 2222::/64
dns-server 2222::250
domain-name ipv6test.com
ipv6 dhcp pool pppoev6
prefix-delegation pool ForPPPoELAN
dns-server 1111::250
domain-name ipv6test2.com
ipv6 multicast-routing
vpdn enable
vpdn-group pppcon
! Default L2TP VPDN group
! Default PPTP VPDN group
accept-dialin
protocol any
virtual-template 2
l2tp tunnel receive-window 512
crypto pki trustpoint TP-self-signed-2636929467
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2636929467
revocation-check none
rsakeypair TP-self-signed-2636929467
crypto pki certificate chain TP-self-signed-2636929467
license udi pid ISR4221/K9 sn FGL2622L6HL
license accept end user agreement
license boot suite FoundationSuiteK9
diagnostic bootup level minimal
username cisco privilege 15 password 0 cisco
redundancy
mode none
bba-group pppoe global
virtual-template 1
interface GigabitEthernet0/0/0
description WAN
ip address dhcp
ip nat outside
negotiation auto
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ipv6 nd autoconfig default-route
ipv6 dhcp client request vendor
interface GigabitEthernet0/0/1
ip address 192.168.99.1 255.255.255.0
ip nat inside
negotiation auto
pppoe enable group global
ipv6 address 2222::1/64
ipv6 nd managed-config-flag
ipv6 nd other-config-flag
ipv6 dhcp server pool2222
ip virtual-reassembly
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0/1
ip mtu 1492
ip nat inside
ip tcp adjust-mss 1452
peer default ip address pool pppoe
peer default ipv6 pool ForPPPoE
ipv6 enable
ipv6 dhcp server pppoev6
ppp mtu adaptive
ppp authentication chap pap ms-chap ms-chap-v2
ppp ipcp dns 8.8.4.4 8.8.8.8
interface Virtual-Template2
ip nat inside
peer default ip address pool vpn_pool
no keepalive
ppp encrypt mppe auto
ppp authentication pap chap ms-chap ms-chap-v2
ip local pool pppoe 192.168.99.151 192.168.99.200
ip local pool vpn_pool 192.168.150.151 192.168.150.200
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
access-list 1 permit any
ipv6 local pool ForLanPC 4444::/48 64
ipv6 local pool ForPPPoELAN 3333::/48 64
ipv6 local pool ForPPPoE 1111::/48 64
ipv6 access-list dhcpv6
permit icmp any any
permit ipv6 any any
control-plane
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
password cisco
login
transport input ssh
line vty 5 15
login
transport input all
ntp server 34.208.249.133
end
6 Replies 6
this second post, first one was about PPPoE.
the previous one solved and now you use different protocol ?
PPPoE issue has reloved. I add the PPTP/L2TP vpn server on same router because we need to create a testbed.
Thanks for you feedback.
I reference the document you provide and change the configuration on router. but the issue still occur.
It is the configuration on router
vpdn enable
vpdn-group pppcon
accept-dialin
protocol any
virtual-template 2
no l2tp tunnel authentication
l2tp tunnel timeout no-session 600
interface Loopback1
ip address 192.168.150.1 255.255.255.255
ip unnumbered Loopback1
ip nat inside
no keepalive
vpdn enable
vpdn-group pppcon
accept-dialin
protocol any
virtual-template 2
l2tp tunnel timeout no-session never
interface Loopback1
ip nat inside
ip nat inside
no keepalive
Do above change and check again,
Now don't show below error message on Cisco ISR4221 router but PPTP client still can not connect to Internet.
vpdn enable
vpdn-group pppcon
accept-dialin
protocol any
virtual-template 2
interface Loopback1
ip nat inside
no ip virtual-reassembly
ip nat inside
no keepalive
