Need Help Setting Up Routes on a Cisco ASA 5505
donnabarney
I'm trying to set up a Cisco ASA 5505 and need some help with routing. I'm mainly setting things up through ASDM but I also have console access. Right now while I'm setting it up I have the outside/Vlan2 port attached to my existing network and a laptop connected to the inside/Vlan1 port. More info about that:
interface Vlan1
nameif inside
security-level 100
ip address 10.10.153.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.10.152.9 255.255.255.0
Here is what my current routing table looks like:
Gateway of last resort is 10.10.152.1 to network 0.0.0.0
C    10.10.152.0 255.255.255.0 is directly connected, outside
C    10.10.153.0 255.255.255.0 is directly connected, inside
S*   0.0.0.0 0.0.0.0 [1/0] via 10.10.152.1, outside
Before I added that last "0.0.0.0" entry, the ASA would not see anything on the internet. Now I can ping any external IP address from the router's console. However, the laptop I have connected to the 'inside' port still cannot reach any IP address outside the 10.10.153.0 network. Every time I try to add a similar route for the 'inside' interface, I get the following error: "You have another route configured for this network any which has same gateway 10.10.152.1 and same metric 1. You cannot add a duplicate route." I know I'm misunderstanding something here. In order to make devices connected to the 'inside' port connect to the internet, I need to set up a new route that will direct these devices to 10.10.152.1, right? What am I doing wrong here?
9 Replies 9
Jeff Van Houten
Level 5
Level 5
Devices on the internal network need to have a gateway of the internal address of the Asa. Most likely the problem is somewhere else, not in routing. What does the NAT configuration look like?
This is what show nat tells me:
ciscoasa# show nat
NAT policies on Interface inside:
  match ip inside any inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 0, untranslate_hits = 0
  match ip inside any outside any
    dynamic translation to pool 1 (10.10.152.9 [Interface PAT])
    translate_hits = 58, untranslate_hits = 22
  match ip inside any _internal_loopback any
I didn't change anything from the defaults in NAT, at least not intentionally.
Donna,
Can you post the following:
sho run nat
show run global
What other networks do you have on the inside other than the one that's on the inside lan now? Can anyone on the 153 subnet get out to the internet?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
ciscoasa# show run nat
nat (inside) 1 0.0.0.0 0.0.0.0
ciscoasa# show run global
global (outside) 1 interface
ciscoasa#
I'm not sure if I understand your question, but the only subnet I have on the inside interface is the 153 subnet. Nothing on the 153 subnet can ping anything on the 152 subnet nor anything on the internet.
Can you post your complete config (remove public information if there is any)? What's on the other side of the 152 subnet? Can you describe a bit about how your network looks?
HTH,
John
Well right now just for while we're learning how to set it up, we have the Cisco ASA 5505 outside port connected to our existing local area network. Although our Comcast cable modem acts as the DHCP server on our network, I statically assigned the outside port of the ASA to 10.10.152.9.
Connected to the inside port of of the ASA I now have two laptops. They cannot ping anything outside of the 153 subnet.
Here is my out put for `show run`:
ciscoasa# show run
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 10.10.152.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 10.10.153.100-10.10.153.199 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
call-home reporting anonymous
Cryptochecksum:e018a63b57c88e8d079b34c9c1b6cd53
: end
you have 2 options:
1° create an ACL permitting icmp and attach it inbound on the outside interface
  access-list icmp_out_in permit icmp any any
  access-group icmp_out_in in interface outside
or
2° enable icmp inspection
policy-map global_policy
    class inspection_default
     inspect icmp
Regards.
Alain
Thanks a lot cadet alain. Adding an icmp exception did the trick. However, I just realized that the laptops on the 153 subnet can't ping each other. I tried adding a similar icmp exception on the inside interface but that didn't seem to work. Is that still a firewall issue or do I need to do something else?
this shouldn't be the asa this time but maybe a software firewall on the hosts that is blocking the pings.
Regards.
Alain
