Need Help to assist with PUTTY script
Hi Team,
We want to create script for "show logging" command to verify with all of our network device.
Since, we got so many switches and routers, Is it possible to create script through PUTTY?.
Please give us script and procedure to upload.
Thank you
thiland
Level 3
Level 3
I'm not sure exactly what you're trying to achieve, but here are possibilities:
  • If you want to collect the logs from a router, use syslog ("logging host") and a syslog collector like Splunk
  • If you want to issue commands simultaneously to multiple devices from a CLI session, I'd get SecureCRT and use Command/Chat Windows to all devices.
  • If you want the router to run "show logging" and send you the output, use Embedded Event Manager (EEM) from within the router.
Hi , We have a lot of network devices, we want to see "show logging" output with every devices.
Currently we are manually Login with each devices and seeing this output "show logging".
Is there any change to get auto login to get output through "PUTTY".
Please let us know script code to enable with putty.
I hope you understood.
Thank you
