Need help to choose a right router
ewong0088
Any idea and help is appreciated.
Currently I have a 10MB Internet connection (ethenret straight from provider) and am going to upgrade this pipe to 100MB. The hand-off is Ethernet RJ45. While there are many choices, the cost is a concern (who doesn't have this problem these days?). I am not doing any BGP nor going to run any services on the router itself. I read somewhere saying I can even use a L3 switch, which I do have right now behind the existing ISP provided router(that 10MB) pipe. A new router is the preferred way and if L3 switch can be used that's greate too. Pros and Cons?
Thank you all.
16 Replies 16
paolo bevilacqua
What is the expected traffic amount ? You can pretty much use any ISR router, sometime seems like there are too many types to chose from.
Joseph W. Doherty
Generally, routers offer features, L3 switches provide speed. So, for instance, for even just one 100 Mbps link, you might want at least a 3845 while a Catalyst 3560-8PC could easily handle the same load.
Yet, for Internet you note you won't run any services but what about NAT? I believe most L3 switches don't offer it but most routers would. What about a FW? Both devices provide basic ACLs but the router can be had with a FW feature set.
PS:
BTW, there are "Metro" L3 switches which offer some addtional features not usually found on most typical LAN switches.
I do not agree that one necessarily needs a 3845 to terminate a 100 Mbps internet circuit.
One reason, 100 Mbps is just a physical access speed but in reality you might be capped to 50, 30 or even less either by ISP policies, or simply not enough actual traffic.
Also, I would be very wary of using a L3 switch that does not have the full set of features most desired like Firewall, VPN termination, sophisticated NAT, voice, etc.
Anyway, that is one FAQ item and then each one chooses based on budget and his own parameters.
Attached, what cisco says about router performance.
Thank you.
Actually, the 100MB is the, more or less, guaranteed speed. Less than that, I'll pull out the SLA and yell :)
In terms of L3 switch, I do have 3750G behind the existing router and F/W in between. I was misled from the beginning that a 2811 will work "well" by the ISP. Yes, I did read the performance guide. The bottom line is that I would like to get a router that will server my need but not to pay more for other features I know I am not going to need or use. The ISP suggested (comes clean?) Cisco 7204VXR (400 Processor) or Cisco 7204 VXR/225/FE. I think it's way over kill for what I am going to use the router for.
Thank you all.
A 7200 is not an overkill if you're going to handle close to 100 mbps bidirectional. That is actually the preferred choice of most corporate users doing "serious" networking.
Note that NPE-225 is seriously obsolete by today, and NPE-400 can be had cheaply. An NPE-G1 would have a much longer technological life.
Thank you.
Any ballpark number on this one as mentioned? "NPE-400 can be had cheaply"
Glad that I ask the question here.
Check the popular auction site, there are many reputable dealers competing for business.
Please remember to rate useful posts with the scrollbox below.
For 100 Mbps Ethernet, for minimum size packets, requires 148,810 pps. Duplex then would require 297,620. The NPE of the 7200 series correspond with their PPS rate, so "technically" a NPE-300 or faster would be needed to guarantee line-rate for any packet size.
Do keep in mind, you often need to have some extra CPU cycles for "other stuff". Larger packets sizes (much) reduce the required PPS rate, although don't assume a router will proportional scale (most, though, can support more "bandwidth" as packet size increases).
For reference the 3845 I mentioned (as seen in Paolo's attachement) provides 500,000 PPS.
"I do not agree that one necessarily needs a 3845 to terminate a 100 Mbps internet circuit. "
Nor do I, although the reason I recommended it "as least", pretty certain it would be safe bet (similar to your mention of a NPE-G1). A smaller ISR might work just fine, although we know from later posts that a 2811 doesn't. Something like a 2851 or 3825 might be "just right".
[edit]
If truly nothing but routing is needed, and without full Internet BGP tables, the least expensive option would likely be a small L3 switch.
Joseph, I see your point, on the other hand I'm 100% sure that if I was to put a L3 switch as "internet router" into one of my accounts, one week later I would have to replace it with a true router, because it can't do [insert nice feature here] to which we are all well used.
Thank you all.
I talked to one of our vendors and he suggested either:
(1) ME3750 with IP Services Image
or
(2) 7201
I wish I had checked the router performance guide earlier, instead of believing what the ISP says. How naive I was.
Thanks.
Do you do or plan to do GRE / IPsec tunnels ? A very common occurrence / that puts the 3750 out of the game. And there are many more.
I am not planning to do GRE or IPSEC tunnel on this (whatever form it will be) device. IPSEC will be on the F/W behind this new device.
Thanks.
So what the router ultimately does for you ?
You could connect the ISP handoff straight to FW.
Then, in most cases a router can replace a FW, but that's another matter.
