need help to make frame-relay switch.
syjeon
Hi.
I have some trouble to make frame relay switch for our lab.
I've configured as instruction guide , however, it seems to be not working now. could you check the our configuration?
configuration.1
frame-relay switch
### two serial interface is attached, serial 0/0/0 is router 1 , and serial 0/0/1 is router 2.
so, R1 is mapped as 102 and this packet will be trasnfered to router 2, regarding below frame-relay switch configuration.
frame-relay switching
interface Serial0/0/0
no ip address
encapsulation frame-relay
clock rate 2000000
no frame-relay inverse-arp
frame-relay lmi-type cisco
frame-relay intf-type dce
frame-relay route 102 interface Serial0/0/1 201
no ip address
frame-relay route 201 interface Serial0/0/0 102
and then I checked the pvc status each frame-relay pvc , but the result as below
show ip int brief.
Serial0/0/0                unassigned      YES NVRAM  up                    down
Serial0/0/1                unassigned      YES NVRAM  up                    down
show frame-relay pvc
DLCI = 102, DLCI USAGE = SWITCHED, PVC STATUS = INACTIVE, INTERFACE = Serial0/0/0
from here, frame-relay switch configuration. below is R1 and R2 serial configuration will be provided.
! - primary interface configuration is same as R1, and R2.
interface Serial0/2/0
no ip address
no keepalive
no fair-queue
R1
interface Serial0/2/0.102 point-to-point
ip address 142.13.13.1 255.255.255.0
snmp trap link-status
frame-relay interface-dlci 102
R2
interface Serial0/2/0.20 point-to-point1
ip address 142.13.13.2 255.255.255.0
frame-relay interface-dlci 201
I wonder when I check with 'show frame-relay pvc', R1 is ACTIVE and R2 is marked as STATIC
all platform is cisco 2800 router,
I don't know why It is not working ...
please help me.
Manish
frame-relay intf-type dce relates how the interface will function in a logical way in Frame Relay. This is quite independent of whether the interface physically is DCXE or DTE.
I believe that this is the fundamental problem. In Frame Relay the LMI is the keepalive mechanism. So on the Frame Relay switch LMI/keepalive is configured but on the router it is turned off.
no keepalive
I suggest that you remove the no keepalive from the interface configuration and let us know if it works better.
Rick
Rick
7 Replies 7
manish arora
Level 6
Level 6
Do not see clocking on s 0/0/1 connecting to R2.
Manish
I can't configure clock rate on S0/0/1, if I configure ' clock rate xxxxx' on serial 0/0/1, then the error message was appreaed up as ' this interface type is DTE so I can't configured brbrbr...' So, I've configured the clock rate on S0/2/0 on router 2.
except, clock rate, Is there any other symptoms?
so why do i see :-
no ip address
if its DTE
Manish
also switch the lmi's on the fr switch :-
no ip address
frame-relay route 102 interface Serial0/0/0 201
no ip address
frame-relay route 201 interface Serial0/0/1 102
Here's a good link for you :-
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml#topic7
check Frame relay switching topic in it and also why line protocol is down.
Manish
Manish
no keepalive
Rick
Rick
Thanks Richard.
It works fine.
I am glad that you got it working and that my suggestion led you to the solution. Thank you for marking the issue as resolved (and thanks for the points). It makes the forum more useful when people can read about an issue and can know that they will read the solution to the issue. Your marking the question as solved makes this obvious to the readers and helps the forum.
Rick
Rick
