Need help to reset my old cisco 860 series.
rupesh97
Hi @everyone,
I have my very old Cisco 860 series.
I would like to reset my router but I couldn't able to reset it through the reset button or ROMMON mode.
All it does is go through some start-up things and it gets looped again and again with the same process which is shown in the picture.
I tried all the possible methods to reset the device but no idea what's going on!
If anyone has ideas or suggestions please drop your feedback.
Rupesh
9 Replies 9
balaji.bandi
PASSWORD RECOVERY  FUNCTIONALITY IS DISABLED.
You have to use the Console cable - Power of the Router and Power on the Router
Putty use the combination of CTRL+ BRAK or  PAUSE Key - keep Pressing until you see
Do you want to reset the router to factory default
configuration and proceed [y/n] ? y
Once its booted - you can use below command to disable
Router# configure terminal
Router(config)# no service password-recovery
Router(config)# end
Router# Write
BB
Hi Balaji,
Thank you for your feedback.
But it does not bring any
I tried many times but it just self-booting  and doing
Booting flash:/c860vae2-advseck9-mz.SPA.156-3.M3a.bin
IOS Image Load Test
___________________
Signature did not verify
Signature cannot be verified, exiting
Turn off the router, Connect console cable and Turn on the Router  - post complete boot logs until you see the Router prompt.
break keys should work  if you using putty :
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/12818-61.html
BB
Above my terminal config.
 Most importantly, I don't see my router prompt after the boot logs.
I tried different terminals as well to break into the router prompt, but I couldn't able to do anything.
post complete boot log in text
BB
pascualt
I also have an older model Cisco 860 series and I had to update the firmware because I was having problems with Telecable, my telecom operator.
Thank you very much for the information!
Apostar por la comunicación y el mundo de las telecomunicaciones me ha permitido conocer de primera mano las mejores tarifas de movil e internet vigentes en la actualidad.
Hi Pascualt,
How do I update my firmware?
could you please advise?
To upgrade the firmware you need to have access to Router - either Console or SSH (which you do not at the moment, so you need to fix ROMMON getting access - since you have the router
BB
