Need Help with connecting to routers . . . .
I am having a problem of connecting to some routers. I have attachted a picture of what I have laid out but I am starting to learn how to do this type of stuff, since I am in college. Any help will be much appreciated.
9 Replies 9
I know how to do the commands, but my problem lies with the serial ports (s0 and s1). These serial ports go up then go back down. They don't stay up. What am I doing wrong?
int s0
ip address 126.110.10.5 255.0.0.0
no shut
Message shows status is up, then a minute the status goes down.
Confused ?
do you have one inerface setup as the dce and the other as the dte?
I tried to setup clocking but the alive time is 10sec and by the time I get into the other right it times out. I have two terminals that are suppose to see each other through 5 routers.
I am confused as how to go about connecting this up since my ethernet ports work but my serial ports don't?
About DCE and DTE, I know what they are but I am having a problem as how to setup that up as well.
Confused ????
I have figured out how to get the ethernet ports working on each router and they are seeing each other. But I am experiencing a problem with the serial ports. Here is what I got as an error message.
Serial0 is up, line protocol is down.
and I also get this one.
Serial1 is up, line protocol is down.
I am trying to configure 2611 cisco routers and 2 PC's on a network simulator.
The PC's and some of the routers are ethernet and some are serial.
Any advice or help is much appreiciated.
Thanks in advance.
Denise
sh controllers serial 0/0/0
Gives me this output
Interface Serial0/0/0
Hardware is HWIC-Serial
DTE V.35
Notice this is a DTE interface, if the other end is a DCE interface I need to provide clocking on that router only:
clock rate 64000
Now I need to configure encapsulation. HSDL is the default cisco encapsulation, but I am going to configure PPP:
encapsulation PPP
*Oct 5 16:53:02.626: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to up
Now apply my IP addresses and test
int s0/0/0
ip address 192.168.0.1 255.255.255.0
exit
ping 192.168.0.2
Sending 5, 100-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/57/60 ms
Now I can take it to the next level with authentication (either pap or chap) I am going to configure chap since it is the most secure:
R1:
ppp authentication chap
ppp chap hostname R1
ppp chap password CISCO
username R2 password CISCO
R2:
ppp chap hostname R2
username R1 password CISCO
Ping again to test, if I have trouble debug:
debug ppp authentication
What if your device is showing HD with numbers in the end?
What type of device shows that it is a DTE or a DCE device?
If it does'nt how do you change it?
I have been looking at this for about 2 days and I am somewhat still confused.
Please post any help, your help will be much appreciated.
Thanks in advance.
Denise
>>Can you post your output and I will try to explain
>>When you have serial interfaces connected back to back (that is directly connected with a cable) one end of the cable is physically wired as a DCE and the other is wired as a DTE. The DCE end needs to supply clocking. See these links:
http://www.cisco.com/en/US/tech/tk713/tk317/technologies_configuration_example09186a00800944ff.shtml
http://www.cisco.com/warp/public/116/ppp_back.html
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3c.shtml
It looks like you're using a simulator for practice, in this case both ends may appear to be DTE, so you wouldn't need to enable clocking.
I am using a simulator that was given to me for practice.
I am trying to get the serial ports and the line protocol both up. If they are both up, I will be able to connect to the other devices such as routers and PCs.
Here is the information I get.
Router# show interface serial 0
Hardware is HD64570
Internet address is 126.110.0.5/8
MTU 1500 bytes, BW 1544 Kbit, DLY 1000 usec, rely 255/255, load 1/255
Encapsulation PPP, Loopback not set, keepalive set (10 sec)
LCP ACKRCVD
Closed: IPCP, CDPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of show interface counters never
Queueing strategy: fifo
Queueing queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
0 packets input, 0 bytes, 0 no buffer
Recieved 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input erorrs, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 input packets with dribble condtion detected
0 packets output, 0 bytes, 0 overruns
0 bables, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
you need to use the: sh controllers serial 0 command to see the cable type. This is the wrong command.
