Need help with my port forwarding config
oliver.mercado
interface GigabitEthernet0/0
ip address x.x.x.36 255.255.255.248
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
ip address 192.168.1.3 255.255.255.0
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside source static tcp 192.168.1.252 22 x.x.x.36 6922 extendable
ip route 0.0.0.0 0.0.0.0 x.x.x.33
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit any
Anything wrong with my config? port forwarding to my ssh wont work. Im using CISCO 1900 Series.
Thank you..
10 Replies 10
Bilal Nawaz
Hi Oliver,
Could you please try this:
ip nat inside source static tcp 192.168.1.252 22 interface gi0/0 6922
Anything coming in gi0/0 on port 6922 will be forwarded on to 192.168.1.252 on port 22.
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
thank for the reply Bilal. I tried that but I still can't connect to my ssh server (192.168.1.252).
here is my sh ip nat trans
Pro Inside global      Inside local       Outside local      Outside global
tcp x.x.x.36:6922 192.168.1.252:22  27.x.x.167:50572 27.x.x.167:50572
tcp x.x.x.36:6922 192.168.1.252:22  ---                ---
Could you do:
ip nat inside source static tcp 192.168.1.252 22 22.x.x.36 22 extendable
Could you try the same port number i.e. 22
I tried that one also... still can't connect to my local server.. I dont have any acls would that be a probem?
No, ACL is used for your PAT. Check you again the server's TCP/IP settings and issue a 'telnet 192.168.1.252 22' from the router?
oliver.mercado
I can telnet from cisco to my local server...
Trying 192.168.1.252, 22 ... Open
SSH-2.0-OpenSSH_4.3
Protocol mismatch.
                  [Connection to 192.168.1.252 closed by foreign host]
Ok. Can your server ping 192.168.1.3 and 8.8.8.8?
Kindly post show run and hide sensitive data.
I know this might be a silly question, so appologies in advance. What is the default gateway of the local server?
Should be 192.168.1.3?
Your translation seems fine.
I just tried this quickly in a lab and worked. This is what I did:
R1 config:
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
R2 config:
ip address 1.1.1.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip nat inside source static tcp 192.168.1.252 22 interface FastEthernet0/0 22
R3:
ip address 192.168.1.252 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.3
Output is here:
R1#ssh -l bilal 1.1.1.2
Password:
R3#
R3#exit
[Connection to 1.1.1.2 closed by foreign host]
R1#
R2#show ip nat translations
tcp 1.1.1.2:22         192.168.1.252:22   ---                ---
R2#
R2#
R2#
R2#
*Mar  1 00:47:19.799: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11730]
*Mar  1 00:47:19.835: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7189]
*Mar  1 00:47:19.863: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11731]
*Mar  1 00:47:19.895: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7190]
*Mar  1 00:47:19.931: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11732]
*Mar  1 00:47:19.943: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11733]
*Mar  1 00:47:19.955: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11734]
*Mar  1 00:47:19.959: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7191]
*Mar  1 00:47:19.967: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11735]
*Mar  1 00:47:19.975: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11736]
*Mar  1 00:47:19.987: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11737]
*Mar  1 00:47:19.995: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11738]
*Mar  1 00:47:20.007: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11739]
*Mar  1 00:47:20.019: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11740]
*Mar  1 00:47:20.099: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7192]
*Mar  1 00:47:20.115: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7193]
*Mar  1 00:47:20.127: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11741]
*Mar  1 00:47:20.147: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11742]
*Mar  1 00:47:20.171: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11743]
*Mar  1 00:47:20.191: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7194]
*Mar  1 00:47:20.211: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11744]
*Mar  1 00:47:20.235: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11745]
*Mar  1 00:47:20.243: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7195]
*Mar  1 00:47:20.263: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7196]
*Mar  1 00:47:20.283: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11746]
*Mar  1 00:47:20.295: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11747]
*Mar  1 00:47:20.503: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7197]
R2#
R2#
*Mar  1 00:47:22.323: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7198]
*Mar  1 00:47:22.343: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11748]
*Mar  1 00:47:22.359: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11749]
*Mar  1 00:47:22.559: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7199]
R2#
*Mar  1 00:47:24.363: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7200]
*Mar  1 00:47:24.395: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11750]
*Mar  1 00:47:24.423: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11751]
*Mar  1 00:47:24.631: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7201]
R2#
*Mar  1 00:47:26.443: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7202]
*Mar  1 00:47:26.695: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11752]
R2#
*Mar  1 00:47:56.907: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11753]
*Mar  1 00:47:56.927: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7203]
*Mar  1 00:47:57.023: NAT*: s=192.168.1.252->1.1.1.2, d=1.1.1.1 [7204]
*Mar  1 00:47:57.055: NAT*: s=1.1.1.1, d=1.1.1.2->192.168.1.252 [11754]
R3#debug ip packet
IP packet debugging is on
R3#
R3#
*Mar  1 00:48:18.923: IP: tableid=0, s=1.1.1.1 (FastEthernet0/1), d=192.168.1.252 (FastEthernet0/1), routed via RIB
*Mar  1 00:48:18.923: IP: s=1.1.1.1 (FastEthernet0/1), d=192.168.1.252 (FastEthernet0/1), len 44, rcvd 3
*Mar  1 00:48:18.927: IP: tableid=0, s=192.168.1.252 (local), d=1.1.1.1 (FastEthernet0/1), routed via FIB
*Mar  1 00:48:18.931: IP: s=192.168.1.252 (local), d=1.1.1.1 (FastEthernet0/1), len 44, sending
*Mar  1 00:48:19.007: IP: tableid=0, s=1.1.1.1 (FastEthernet0/1), d=192.168.1.252 (FastEthernet0/1), routed via RIB
*Mar  1 00:48:19.011: IP: s=1.1.1.1 (FastEthernet0/1), d=192.168.1.252 (FastEthernet0/1), len 40, rcvd 3
*Mar  1 00:48:19.031: IP: tableid=0, s=192.168.1.252 (local), d=1.1.1.1 (FastEthernet0/1), routed via FIB
*Mar  1 00:48:19.031: IP: s=192.168.1.252 (local), d=1.1.1.1 (FastEthernet0/1), len 60, sending
Seems to work with this config.
Hope this helps.
